Schematic for Tannoy TS-10 (or TS8-TS12)?
If anybody is interested, I have the schematics for the TS-12.
At the same time I ask if anyone has experience in repairing the
power supply. (Switch mode power supplies are not my virtue).
A start would probably be to exchange the obviously burned passive parts
and the semiconductors nearby them, but ho w to proceed then ?
Turn it on and hope for the best ?
Would it make more sense to buy a supply with the required voltages or
build an analog one ? (The last option would at least be easy for me.)
Have you tough about sealing the back of the TS10 with plywood putting some kind of speaker connectors and buying something like this? Bash 300S Digital Subwoofer Plate Amplifier 300W RMS it is basically the same amp. That is what i did with mine I can't tell the difference in sound
If buying a Bash 300S as a replacement, I guess it may make more sense to simply swap the boards... that way you do not end up with a kludge... 😀
Changed one irf540 and two irf740 transistor , and one DB-6 Diac Trigger Diodes, which now can neither find where to buy (((
Send someone to Russia I two DB-6 Diac Trigger Diodes in the envelope?? )))
