Free Horns
I have a pair of Bruce Edgar designed and made tractrix horns. They are his #5 from 1993, which means it's intended for 500Hz and up. I've measured them and they are actually 260Hz horns. They are in birch veneer plywood boxes that are in good shape. I used Dynaudio D54 drivers with them but they are not included. They have a 2" square throat. Local pickup only. I will not ship these anywhere. I can provide photos if anyone is seriously interested.
Here they are.
Probably shouldn't post the good Dr.'s phone number without his permission???
Oh, not intended to do that, but that's from 20 years ago!
I have decided that I am willing to ship these after all. The charge is about $67 via UPS ground EACH for across the country to California, not including the cost for the box and bubble wrap. I don't have an estimate for those items right now, sorry. The horns weigh about 40lbs each.
OK, just so everyone knows, the upper frequency limit of the horn's response is a function of the driver that you choose to use with it, not the horn itself so much. Like any tractrix horn, it will start to beam at higher frequencies. I measured these horns and they are actually something like 280Hz or so as a lower cutoff, but being a tractrix the response doesn't go that low.
I mean I measured the mouth dimensions and the length and the throat size and put it all into Hornresp software and that's what it told me.
