Cheap 10inch woofer in tapped horn? what would you do?
I wouldn't've said it's a standard TL either. Not sure what it is, though - there's that many drivers that ones of each distance from the mouth will see a different tuning, so it would probably be difficult to simulate what's happening.
If it was me, I'd try blocking the port: below whatever tuning it is, the drivers will unload completely, giving lots of excursion, but relatively little output.
If you could get an impedance curve of the subwoofer as a whole, we might be able to see what's going on.
Chris
impedance is fairly flat from 20 - 80Hz, at about 2.5ohm, with a single peak at about 28Hz...
and the impedance decreases under 20Hz down to 1ohm at 10Hz... from memory...
it was designed to use the car as part of the box, to act as a tapped horn, so the drivers are then the same distance from the back wave to the front wave 😉
this is in the car the impedance measurements were made, because its intended to be used in the car 🙂
issue is, that the dayton woofer tester will give fairly varying results.
just been playing around with the dayton woofer tester again.
measuring "t/s specs" with the drivers in the box, and in the car.
generally the WT will report an FS of around 24Hz, but sometimes (1 out of 5 maybe?) it will claim an FS of 50+hz.
I'll post some photos of the impedance plots, most have been changed to only display 10 - 100Hz, and 15ohm maximum impedance, while others show the full frequency range...
pics to come! I'll let you all decide if its a transmission line, or a high tuned box...
my mistake... 1Hz - 100Hz 😛
Does this mean the dual eight 10" driver tapped horn is now in the mix?
Congrats on your subwoofer box, insanity is not simple. I'm putting my big toe in the tapped horn pool with a single ten--jump in and bring your 16 tens with you...the water is warm!
Something's not right there. If the WT3 is not giving consistent results, then you need to investigate why and fix it. For example, remove any possible external factors that might be interfering with the measurements (e.g. take the measurements with all windows up, the car off and the subwoofer disconnected from the amplifier).
Old thread I know, but for what it's worth, one cannot measure T/S parameters since the speakers are in an enclosure. The reason the specs come in differently is not because of cone area as had been suggested, it is because there are two main impedance minimums, which then causes several impedance peaks which is what the WT3 looks for when calculating T/S parameters; but with two peaks it is surely getting confused and doesn't know which one to "hone in" on because a free-air (or baffled) speaker only has one impedance peak from which to extract T/S parameters.
Really? I thought WT3 was supposed to be able to measure this too. You'd use it within those circumstances when adjusting an AP membrane to achieve the tuning you want- I haven't done this myself yet, but know of others who have.
Measure what, impedance? Of course, one of it's main functions is to generate an impedance curve that can be a tool for tuning an enclosure. I wasn't attempting to debate that, simply stating that the WT3 cannot "look" for parameters while a speaker is installed in an enclosure.
The intent was to use the WT3 to measure the impedance response, not the t/s parameters.
..then perhaps I misunderstood your reply to that post. I know you know your stuff😛
lol, nice thread. What are you doing with the drivers now?
they're sitting in the basement (aka, "rape dungeon")
I have 18 of them now, one the rubber gasket on the front is completely unglued 😛
and nearly all of them are starting to de-laminate, so the yellow "kevlar" is separating from the cone surface 🙁
they didn't last long...
however, I still plan to make some tapped horns for them, probably when I'm not living in my parents house...
