I have two amps: one (mono) for subwoofer and the second (stereo) am trying to connect to the same psu.
One case houses the mono amp and the transformer. The stereo amp has its own rectifier and filter caps and connected to the power transformer inside the case.Both amps are silent with no RCA cable connected. There is a hum when the cable is connected without the source.When I connect the source(pc)and break the ground loop between the inputs of the two amps,there is a hum from one of the amps(the one whose ground input is disconnected).
How can I solve this problem?
Regards.
Regards.
Ground Loop Isolator - RadioShack.com
or for 10x the price:
JENSEN TRANSFORMERS, INC. - ISO-MAX® CI-2RR Stereo Audio Input Isolator
Whitlock's seminar handout paper is really good intro to the issues:
http://www.jensen-transformers.com/an/generic seminar.pdf
Try rotating the power plug, switching the AC input pins. In a few cases can this remove the problem.
Swapping Active For Neutral? 😱Try rotating the power plug, switching the AC input pins.....
Ian, there are some countries that dont have polarised power outlets. However in these countries, neutral and ground are usually never bonded together, and neutral is treated as a "live" line. Neutral to ground shorts will trigger an RCD in such cases.
Quite so...We are not all MEN system but a little qualification is in order -hence the "shock horror" rather than objection.
Ok - now you have me curious but couldn't locate the details of Kenya's earthing system. The system is officially using UK outlet fittings,
so it will require a little work to swap connections over but that also suggests a good reason not to try it.
Is this reference info correct in Kenya, Xeclipse?
Leads Direct - Mains Wiring
That's correct,a three pin plug but I have connected only two:live and neutral(the amp is in a wooden case). The pc has all the three connections.The system is officially using UK outlet fittings,.......
Regards.
- Amp hum when RCA cable is connected
