Wavebourn, don't you hear the difference in line cords?
Presumably, Wavebourn's amps have competent power supplies.
When loaded on speaker impedance simulator?
And mine don't.
I'm surprised at that admission- I would have guessed that you'd be fine at designing competent power supplies for your products.
You are wrong, SY. It is true that better designing power supplies DOES reduce the sensitivity to line cords, but it does NOT eliminate it. I am very proud of my power supplies, but the best thing that I did for the JC-3 was to put a 10uf cap across the input line to remove the power supply problems and probably power cord sensitivity, at least to the resolution of the JC-3, which is not infinite.
It is very challenging: in order to power amps with zero output resistance he would ned power supply with zero output resistance, powered through a zero resistance power cable from zero resistance outlet. But adding 0.1-0.5 Ohm resistor in series with speaker he allowed some resistance for power cable and outlet. Sounds quite scientific, right?
You are wrong, SY.
OK, so you can't design power supplies.
Sorry, I think you're being overly modest.
Possibly some designer are satisfied with only measurements, while skipping listening evaluations.
Possibly you don't mean my humble person, Joshua?
As people know, I always calibrate measurements with listenings, and listenings with measurements. You know, it helps sometimes more than correlating thinkings with readings.
Last I heard, RF entering an amplifier via the power cord, spreads also by radiation, bypassing the power supply. But what do I know? I have no formal degree to backup any technical claim.
However I'm curious why Thorsten Loesch bothered to put a special AMR fuse in the CDP I purchased recently. Was the fuse chosen after certain measurements? Or may be after listening evaluations? Is that special fuse only for show? I doubt it, since most customers don't bother to take out the fuse and look at it.
I'm pleased to hear it.
Now, in your listening evaluations, did you ever note any difference in sound between different power cords? Did you ever try different power cords?
Joshua;
if you want I can introduce you to one designer in Israel. He is not famous among manufacturers and reviewers because he is perfectionist; he has golden ears and great experience in audio design. Nothing can satisfy him, but may be you can stop his endless improvements saying that his system sounds already nice, better than some other very expensive systems, and it is the time to start manufacturing in order to satisfy listeners?
I did try different approach that renders such tests meaningless: filtering and stabilizing of voltages and currents. Also, transformer balanced inputs help a lot... According to my experience resources are always limited, contradict each other, and have to be applied where they give better results.
“Give me a lever long enough, a fulcrum strong enough and I’ll move the world” -Archimedes
Joshua_G;2816234 Is that special fuse only for show? I doubt it said:I take out all fuses regardless. I would hope no fuse is better than any fuse, I would hate to think they contained the magic smoke.
Joshua;
Do you mean Michael? I know him.
What makes you think I'm up to convincing people to stop their endeavors to improve their sound system? I'm farther from it than I am from other galaxies.
So, have you succeeded building an amplifier which is immune to different power cords?
No, I mean another one, Alex Z. He uses batteries to power vacuum tube phono corrector with LR networks... If you are satisfied by AC powered solid state corrector with RC networks you can probably convince him, no?
Always.
You are welcome to do with your audio gear whatever you please.
I do things differently, that is, I listen to changes prior to deciding anything.
I'm going to try different fuses after the CDP will finis its' burning in.
However I have a feeling that none participating in this thread (other than maybe Thorsten) is actually interested in my findings.
In my other pieces of gear to my audio setup, different fuses definitely mad a change to the sound. However, it seems to me that none who is adhering to ones' beliefs religiously is going to let oneself be confused by facts.
So I let it be.
Each to ones' own.
I only wonder what is the motivation of some people to tell me what I hear and what I don't hear, what have an impact on the sound of my setup and what doesn't.
- Member Areas
- The Lounge
