here the difference between mouth 2200 vs2700 cm2
also you have to deside the form of the mouth.
I will take the 2700cm2 to go
For the mouth use the same cut but the mouth plate slant in a v shape looking a horn mouth.
2 sheets per box with some leftovers
2 sheets per cab that is great.
not syre what you mean ,you can cut the mouth peaces slant.[/QUOT
What I am saying is to design the mouth plate like a horn flare
dims are 122*80*60epa i sim will ok the db seems be the same ,but where is the dimension of this box?
its about 1.5 ~2 db down on the tbx @2.83v
Hi Thawach,
That would restrict the flow of the horn. I don't think it would work.
hi oliver that's only think if do like this. i think epa must rebuild the new plan again.
- Subwoofers
- 18TBX100 vs 2lab12
