ScanSpeak work with Selenium form a centre speaker for AV system
Just Constructed an excellent centre speaker and share with you here. It sounds everything clear but not too bright or dark, just sound natural. Bass is punch with a subwoofer ^_^.
Box Construction, blue is a hole for connector box, red are internal bracing to reduce baffle vibration:
attachment.php
Tweeter:
attachment.php
Woofer:
attachment.php
The messy tuning scene:
attachment.php
Final optimized (critical judgement mainly by listening test) circuit on the crossover:
attachment.php
Frequency Reponse in Real Test. About 1 meter far and tested at low SPL:
attachment.php
Nearfield low frequency response in Real Test (mic very near to driver and port):
attachment.php
Combined nearfield low frequency response in Real Test (the mic is between woofer and port):
attachment.php
Impedance with and without (about 50~70%) dacron filling:
attachment.php
Port length is about 60mm in these test, it can be longer, say 120mm, adjust it by your taste ^_^.
Alvis
Just a reminder:
If you are going to copy my design, you may not be able to find the same horn as it was bought in China, in this case you may order one from PartsExpress but just don't buy those long horn as the delay will make it sucks. My suggestion is to get the shortest horn. For long horn, you may suffer from delay distortion when tuning your crossover. To balance the delay for long horn with passive crossover, you will feel an extreme pain as it is nearly impossible to be perfectly balanced. Using horn is quite tricky ^_^.
