I posted this up over on the Solid State forum, but I think its relevant here as well.
I found this site while rooting around. Fascinating site with a lot of history about the UK hi-fi industry over the last 30 years or so. I knew Stan Curtis was a prolific audio writer and designer, but I has no idea he was that involved on the business side as well, and responsible for some iconic products over the last few decades. A great read.
Stan Curtis, the hifi guru, introduction
Thanks Bonsai.
As you say, a good read. I remember the Stan Curtis CD players getting rave reviews at the time.
Yes, he is probably the UK's #1 audio guy in terms of experience in the industry. The story about the Cambridge amps is very good - I remember seeing the P30 (or was it P60) when I was about 18 and drolling over it - but out of my budget unfortunately.
I think Cambridge inaugurates the low profile style, its first amp came on the market prior the first Mark Levinson phono preamp, I think. They bear some ressemblance :
It would be interesting to see the circuit details for these old timers if anyone has them.
I see mention of driving a squarewave into a 10mf ??? (uF 🙂) with no overshoot or ringing.
I do have the schematics of the P40 - 20W amp and its preamp.
Quite unconventional, this last one. It used a cascade of three virtual ground stages. The first one having a 47 kOhm in series (just like some Linsley-Hood phono preamps) and a gain control pot to avoid any overload. The second one incorporates a mono-stereo switch and the third one deals with the RIAA equalisation.
The amp has a single rail -55V power supply with a single transistor input, a VAS load by a CCS which current of can be nulled by an electronic switch in case of output overcurrent. The output stage is made of darlingtons PNP (2*2N4289 in parallel for the driver, MJ491 for the power) and NPN (1*2N4286 for the driver, 2N5037 for the output).
If interested, I can scan them
Probably quite rounded rendition.I see mention of driving a squarewave into a 10mf ??? (uF 🙂) with no overshoot or ringing.
I think the 10mf is just annotation - it probably is 10uF. 10 000 mF is just about a dead short!
If you look around on his site, there are a few circuit diagrams.
Thanks forr, its curiosity value really as its always interesting to see the topologies used.
It was the description of the "Clasic One" that intrigued me 🙂
Even 10uf would be pretty good going back then. I'll have another read through the site later.
hi all, where can one nowadays obtain dual log 47k pots c/w mains switch as per the p60 volume control/on-off switch. thanx.
You might have to cobble together bits from an old switch to add to the back of a modern vol pot.
But be wary of a metal control knob/stem going into a mains switch.
CE safety regulations sensibly killed off this sort of power switchingYou might have to cobble together bits from an old switch to add to the back of a modern vol pot.
edit - I wish this useful site got updated by Stan
Oh I forgot to thank Paul for his website, took me a little time to place the familiar sounding name🙂 I have a P140X, I guess it is like P110, at that time there was 70x and 140x. Spec say 55W at 8 ohm, 36W at 15 ohm, 110 peak, IHFM 70W, max power (rms voltxrms ampere just befor clipping) 70W.
thanx. the switch has incinerated (heat generated by dirty/worn contacts) so i'll probably have to cobble something together. did think of a small box housing a soft-start but wanted to see if something close to an original was available.
If anyone is interested I have a Cambridge Audio P60 amplifier that is looking for a good home. It is the silver/grey version. I don't think it works although the power light comes on – I have no way of further testing it. It is in its original packaging, and was bought in Carlisle in 1974 at a price of £129. I have the manual and QA statement. Serial number is 600007. Location is nr Kettering in Northamptonshire.
- Analog Line Level
- Stan Curtis site
