Hi there
I have put a passive output in my SCR 2496, it worked fine, but now it is very muffled nearly muted, I bougt a DIY DAC with the AKM AK4396, put a passive output in it and it also is very muffled nearly muted, i use the french article for my output change, that is a high quality cap, 6,8 µF in series, a 2,2 µF paralel and a 1k resistor direct from the AKM DAC chip, am i doing something wrong?
When i use the active stage all sounds normal.
I am no expert, but play around a lot with electronics....
thanks for information, tojoko.
Skip the 2,2uF.
Or use something like this:
http://www.linearaudio.nl/Documents/dcx passive article.pdf
(Figure 2) with or without the muting etc.
If u use unbalanced output, try to keep the load to the + and - out equal. So make it unbalanced after the double filter, (figure 2).
SCR2496
Cheers, Tom.
A bit late, got the wrong Caps, should be 2N2 instaed of 2,2 µF...should have put my readingglasses on, LOL.Hi there
Cheers, Tom.
