I am searching for some viscoelastic glue (or sheet) for constraint layer construction. I found Green Glue in my web searches and also used it. It uses water as a solvent (no VOC) but it therefore works only with material which can absorb water like wood, MDF or gypsum board. It also has a quite low adhesive strength. I would like to use it on aluminum or composites. I assume that the new Magico Q series uses some constraint layering otherwise these speakers would ring in spite of their fancy bracing.
I could find some polyurethane glues which are elastic but not viscoelastic.
I am still looking for a viscoelastic glue. Vibratec is unavailable in the US. Swedac has 2 products: DG-06 (2 component PU) and DG A2 (water based acrylic) but I did not find any supplier either. I have tried Green Glue but it is not working very efficiently in constrained layer. It is not a glue (but green) and is designed for plaster board (2 layers held by screws). Wall damp is identical in these properties.
Many constrained layer constructions use elastic glues/layers (e.g. silicone, rubber) but viscoelastic layers are much more effective. An alternative would be a thin viscoelastic sheet but most I have found are relative thick and loaded with some additives to add mass.
Try the 'inverted moquette'
It is the carpet with gummed base, attached to the walls of the cabinet
not by the base but by the fluffy side
So the gum sheet is free to absorb & flex
There are a lot similar approaches for speaker building (like Black Hole 5) or for automotive applications. Most include (visco)elastic layer(s) with some mass loaded layers but any of these are not what I am interested in: constrained layer cabinet wall construction.
One option would be to coat 1 or 2 sides with a viscoelastic spray like Cascade VB-1S PRO Quiet Kote Damping Spray or similar product (thin coat - 1mm thick). When these coats are dry one glues the 2 layers together with PU. Has anyone experience with that approach?
Have you considered using a sheet of neoprene for the viscoelastic properties? That would allow you to use what ever adhesive works best. Alternatively a elastomeric polyurethane likeVEF-41 may suit your needs.
Polyurethane Viscoelastic Foam Resin
Try contacting Swedac directly - it's a small service minded company.I am still looking for a viscoelastic glue. Vibratec is unavailable in the US. Swedac has 2 products: DG-06 (2 component PU) and DG A2 (water based acrylic) but I did not find any supplier either. I have tried Green Glue but it is not working very efficiently in constrained layer. It is not a glue (but green) and is designed for plaster board (2 layers held by screws). Wall damp is identical in these properties.
A2 is told to be very effective in constrained layer cabinets.
check out the dyad glues: http://www.soundcoat.com/soundcoatdamping.pdf
also, here is a good article on the basic design principles of CLD materials:
http://csaenglive.moogaccess.com/pa...ion_Damping/CSA1995_PassiveDampingSystems.pdf
It mentions a couple of viscoelastic polymers/glues that are available.
IF .. serious, one could look into construction adhesives.
As even a rudimentary start point.
For example: structural glazing utilises a variety of silicone adhesives with distinct and varying Modulus of Elasticity properties.. up to and past 100% even .
PolyU caulks/glues are another. Lotsa choices actually
Time to do some ernest looking ?
This was also a fairly helpful/practical article from 3M:
http://multimedia.3m.com/mws/mediaw...E666666--&fn=Viscoelastic Damping Polymers 11
Roofing Felt
... constrained by masonite sheet. See URL: Loudspeaker construction
Did not read the other posts here; just a quick response.
WHG
WHG
3M has so many sound damping products. Here are some more glues:
3M? NVH Dampening Material, 50 mL, 34274
3M NVH Dampening Material 04274
Most of the better constrained layer damping sheets for cars use butyl with a thin layer of aluminum.
The butyl products stay elastic, most asphalt based products dry out eventually.
It (butyl) sticks very well but I don't think its a substitute for glue. It does do the job gluing the sheets
to a car door and keep it there for years though.
- viscoelastic adhesive
