My Pearl One. Some questions
What is the voltage at the base of Q5. It should be 1/2 voltage of that at the emitter of Q3 (~24v), so close to 12v. If it's not then it could be that your resistors are not both 10k ohm, or there is a solder joint that is not solid, or maybe damage to the transistor Q5.
Thanks John
L. Board:
26,1 volt on Emitter of Q3
20,2 volt on Base of Q5
R18-R21 are 10K
I think that the Q3 is "dead" because yesterday I checked 24,6 on Emitter and 17 volt on Base of Q5
R. Board:
24,6 volt on Emitter of Q3
18 volt on Base of Q5
R18-R21 are 10K
You can measure the resistance of R18 and R21 to ensure they are both 10k.
Yes, I used 10k on R18 and R21
Okay, well, the voltages you get at the base of Q5 on both boards doesn't make sense because it should be very close to 1/2 the voltage of the emitter voltage of Q3. The voltages you measure are much higher than 1/2 that voltage.
So, that's why I suggested you actually measure the resistances R18 & R21 with an ohmmeter, cause there maybe be a problem with a solder connection there or a problem with the Q3 transistors.
Anyway, that's very strange. Hope you can get that solved.
I agree, it looks like Q5 on the left board is damaged.
Well now I would like add a Led on board. Can I used the Pad 4?
Thanks to all for your patience
No ! Pad4 is intended to use a 9V battery in place of the zener if you want ... It's a reference place for the regulation. Don't use that spot or you would add problems !
If you experience too much noise (hiss) in case of low gain cart, you can remove the zener and try to use 9V battery instead. It should be a tad quieter in high gain cases.
I would use a Led + series resistor between V+ and Ground pads. You can use unreg DC if you're suspicious about adding a Led on regulated audio V+. It can be done too, as you wish.
Best,
nAr
Thanks Nar
Ok I'm clear that I should not use the Pad 4.
I take your advice and bring out a led + resistance from the V+ and Ground pads on the PSU.
For about 45 volts. Should I use a very large resistance?
Depends if you use a high efficency one or standard.
Range between 10k and 68k should be ok. For my high eff white ones I use about 137k 0,25W on 48V
Best,
nAr
Hello guys!
I added a 10K resistor to the LED and the result is very good, but when I turn off the LED takes a long time off. I guess adding greater resistance than take off.
I've been testing the masses and how best to go is as I have now (safety Earth).
On the other hand, wanted to ask if the voltage on Q8-12 zone is crucial. I have a voltage of 0.1 V in this area.
LED resistor calc
say that you're going to use +/-18 ; that's 36Vac ;
say that you're going for max 3mA (plenty for any signal LED)
say that you're going for just one diode in series - that's half rectifier , so you'll have (roughly , but precise enough for purpose ) 36/2 x 1.41 volts DC after diode , with modest cap ; say that 10uF/50V is sufficient
so - we have around 25Vdc
R=U/I
R=(25-3,3)/0,003
R=21,7/0,003
R=7233 Ohms
use first standard value - say 7K5
without recalc of current with altered value , we assume that we still have near 3mA
so - dissipation in resistor is :
P=I^2 x R = 0,003^2 x 7500 = 67mW , so any small metal film resistor is good enough ( factor 3 is always min in my book)
so - secondary - just one diode - cap for smoothing - resistor - LED
easypeasy
if LED is still blinding ya from listening position , you can solve that in 3 ways :
1- turn case for 90 degs , so you can't see LED
2- glue something diffuse across LED (foil or something)
3 - increase value of resitor
:clown:
Thanks for your good reply Zen.
I keep your post, since it is very interesting and helpful.
I used the 18 volt (DC) and added thanks to your recommendation a cap 10 uF but I used a 10K resistor.
According to my calculations, the result would be: (18-3.3)/0.003= 4900 Ohm; 5K
The result is very good, turning off with a slow.
