CFP Buffer
What are you thinking about this circuit of CFP buffer? The different is that I remove resistors on emitter on the driver transistors and they always stay in class A mode. What are you thinking about temperature stabillity, i think to put all transistors on one copper heatsink?
Whether it will works good and stable?
Couple of things missing from the schematic...
Missing emitter resistors for the output makes it NOT a CFP...
The DC servo relies on the internal impedance of the source, which may be a problem under realistic conditions.
Why regulate the DC rail that powers a current source since the current source attenuates AC from the rails by several orders of magnitude?
...Missing emitter resistors for the output makes it NOT a CFP...
Yes, that is the idea. What are you thinking about this?
Ok, what is your suggestion?
I'm regulating the DC because i want max effectiveness and stability. I'll try to remove a servo.
What are you thinking about termal stability of the circuit? Alll transistors will be on one copper heatsink.
I don't think it will work (well, ok, maybe for a few milliseconds 😉).
There no current limiting in the drivers. The servo only regulates the DC output level, but the drivers can and will conduct large currents meaning the output devices will conduct even larger currents.
You should use emitter resistors in the drivers as a minimum. They can still be in class A, of course.
Another option is to move the emitter resistors from the output devices to the CFP side that connects to the output.
jan didden
