exaU2I - Multi-Channel Asynchronous USB to I2S Interface
the cMP2 by definition is running in 'Hog-Mode' - it is after all the only this left running on the pc!
That is not the definition of hog mode. Hog mode is a specific setting within CoreAudio that must be requested by the software that is feeding the audio device. You cannot obtain hog mode performance by simply running only one audio program, at least not unless that particular audio program specifically requests hog mode. For example, iTunes will never request hog mode, even if it is the only audio program running.
exa065 has responded with the specifics about the exaU2I, so you can trust him on the details. I just wanted to clarify the definition of hog mode.
P.S. Hog mode is part of CoreAudio, not ASIO.
rsdio,
Your clarification is very punctual and precise as usual. But please, leave some breading space for the regular user. Alan's post is quite clear. He compares Apples to ...not oranges, cMP2. It's OK to use the term "Hog Mode" on both sides - cMP2 Windows ASIO vs. OS X. We understand that It stands for "Exclusive" or Single Client".
Exa...
I have some questions regarding performance claims for the Exa USB interface (if not better than). On this thread you claim that this device has a jitter level as low as any other USB interface. Since I do not see any real jitter measurements at your site, I am wondering what these claims are based on? Certainly an analysis of the analog output of an ESS 9018 based DAC is not very indicative of the jitter at the DACs input-considering that most implementations of the ESS 9018 utilize the DAC in asynchronous mode, re-clocking everything with its onboard ASRC.
If your only methodology to test for jitter artifacts is through the analog output of the attached DAC, I would recommend running the ESS 9018 in synchronous mode (providing the masterclock from I2S from the Exa), and publishing the results on the analog output, this approach would reveal something real about the jitter performance of the Exa.
Another spec which might reveal something relevant about the potential performance of the Exa would be to let potential purchasers know what oscillators are used on the board, and what their phase noise spec at 10 Hz might be. Right now, for a device which costs $400, there seems to be a paucity of real information about how well it really can perform. Of course, as long as you are confident in the design, it will be to your advantage to reveal some more relevant technical information.
I am thinking if can use the board with the DAC inside my Sony SCD-777ES or Korg MR2000S recorder to play DSD files.
The SCD-777ES has internal clock, so I wonder if the board can disable build-in clock and using external clock?
For the Korg, it uses CS4398, it has DSD input pins but the mode setting is by program, so I double it will be easy to deal with. It does look like it can using external clock though.
Can somebody help?
Can somebody help?
Hi ljames, unfortunately it is impossible to use exaU2I with an external clock.
barrows, I've never said that. Of course USB devices are not born equal.
Please read the previous posts in this thread. This question has been answered many times.
exaU2I is designed and optimised for use with ES9018. Previous posts discuss the jitter tolerance of this DAC. It doesn't make sense to turn off one of the most important features of the DAC - the jitter suppression.
Another spec which might reveal something relevant about the potential performance of the Exa would be to let potential purchasers know what oscillators are used on the board.
Again, in the recommended configuration the performance of the onboard clocks has minimal impact on the DAC performance because the I2S stream is relocked with the 100 MHz master clock on the DAC board.
barrows, I can understand that you are unsatisfied. From the point of view of traditional designs it will make sense to use the most expensive clocks, resistors, Teflon insulators etc... We are not interested to compete in this area. We rely on good overall integrity of the design and we don't believe that dollars should be thrown at every component without proven impact on the end result. These of course have a "feel good" effect.
exaU2I is an alternative device. You've tried the best of the main stream. If you are still looking for more, you need to try something different. Try exaU2I, I can offer you a money back warrantee. Your risk is the shipping cost. If you decide to keep it, change the clocks, apply independent power supplies, put extra capacitors, remove the GMRs. Enjoy the DIY journey and share the results with us.
Exa...
So I guess you are confirming my fears that the Exa is really not optimized to produce the lowest possible jitter.
"exaU2I is designed and optimised for use with ES9018. Previous posts discuss the jitter tolerance of this DAC. It doesn't make sense to turn off one of the most important features of the DAC - the jitter suppression."
Some listeners (including ESS designer Dustin) have found that they prefer the sound of the ESS 9018 with synchronous clocking, and (hence) the ASRC and DPLL disabled. Of course, to get the best performance in this mode requires a low jitter source. I personally prefer the ESS 9018 in synchronous clocking mode, as the sound is just a little more natural in regards to timbre without the ASRC.
To suggest that using very low phase noise oscillators is an unnecessary expense appears a little odd to me... Every digital engineer whom I have any respect for has stressed the importance of low phase noise oscillators (running on clean isolated power supplies) for producing the best possible sound.
... As far as DIY is concerned, the exaU2I is offered via the model of "buy one and see if you can modify it to meet your needs." Thus, we have a hammer. When questions are asked, it seems that no details are forthcoming, so I made the snarky remark that every problem must be a "nail." ...
I just wanted to congratulate you with your new thread in the vendor area. It is also nice to see that you still allow critical comments. You are much more likely to get me as a customer with this approach. That being said, I think it would be nice to see some sort of jitter measurements. If it is good it will for sure sell a few boards 🙂
regards,
Øyvin
This question was answered long ago
regards,
Øyvin
Øyvin, this question was answered long ago. Here is my post 211 from 28th March 2011:
"Here is my perspective on the impact of jitter on the exaU2I output. The clocks are responsible for about 2ps of jitter. The FPGA causes about 40ps and the GMRs another 100ps. This would add up to about 108ps on the exaU2I I2S output. Let's assume that it is 20 times more - 2000ps. Here is the jitter sensitivity for Sabre DAC to 2ns of jitter. I don't see any reason to be concerned even if two stages of GMR are as used as presented by RayCtech on the previous page of this thread. "
This is a worst case scenario. Third parties have attempted to measure the jitter and have come up with readings between 40 and 100 ps. We base our modeling on the worst-case scenario.
Thanks for the graph, but it does not appear to be a measurement of the exaU2I. The red line, with higher jitter, is labeled as "a competitor's part" while the dark line, with consistently low jitter, is labeled as "SABRE DAC" ... where is the graph for the exaU2I I2S output?
I think the key point here is that people can look up the part specifications themselves, but they do not want to base their decision on general data sheets, and they do not want worst case models. It seems that people are asking for actual measurements with test equipment designed to indicate jitter.
Forgive me if such test results have been published earlier in this thread. If they have, then might I suggest putting them on your web site since people seem to be remiss to scan this long thread for such information. If the results are there, I'd appreciate a reminder (I may have missed them the first time through).
The graph indicates the ES9018 tolerance to jitter. Please see the original discussion starting on page 22. The worst case scenario for exaU2I is much lower than the 2ns jitter impact indicated in the graph. Further the measurement of jitter is not straight-forward and easy.
What matters is not the jitter on the exaU2I output, but the jitter level at the receiving end - the DAC. For example some USB to SP/DIF devices claim 3ps jitter. This is possible under lab conditions on the near side of the cable. By the time the signal is delivered and received the jitter reading will be off by nanoseconds.
Instead of relying on measurements that will be irrelevant because the impact of the receiving end of the I2S connection is not known, we use the worst case estimate and we make sure that it is within the jitter-cancelling capability of ES9018. Than we evaluate the jitter-related artefacts in the analogue output. It is more pragmatic to verify the end result rather than speculating on measurements that are partial reflection of the reality.
Our measurements on the analogue end correlate with subjective listening tests done by users. This gives us confidence that the balanced approach that we've taken between minimizing noise by using ground isolation and accepting jitter caused by the ground isolation is paying off.
I am not saying that a certain level of jitter/noise is acceptable. exaU2I implements a balance that we believe is optimal. My advice to users is to believe to their own ears. Consider also the opinions of users that have first-hand experience with the device.
I am a very happy exaU2I owner since June.
The performance of your interface is superb and it is dependable. Equally as important, your superb customer service and patient demeanor results in someone I enjoy working with.
Keep up the good work! I look forward to your continued advancements.
George, frankly you have been overly patient with the posters who do not own and are unfamiliar with your product. In my opinion, there is an unjustified and concerted effort to discredit you and your products. Is a hidden (perhaps not so hidden) agenda is at work here!
Two lines from me too - I think I am very representative of a lot of the USB->I2S buyers - I can talk for hours on jitter(it is bad,bad,bad) and what I read it about on forums and how one solution is supposedly better than the other. But I don't really understand it. So what I did is that I BOUGHT most of the available converters and compared them on my Buffalo II. The ExaU2I is in an absolutely different league than most of them. I used to think that GMRs will kill what's good in the Exa but that was when I was trying to imagine how it will sound,I don't care at the moment - I am listening to music.
P.S. I have one old favorite commercial, it kind of says a lot:
Pub Hakkinen/ Becker Mercedes Classe C video on CastTV Video Search
Well,
I haven't posted much because I am no authority of any kind and anyone knows that it is not just one device vs. the other, it would take a full description of the system, the music, how well I have tried to optimize each device and so on. I will only say that I had some of my friends who are not interested in computer audio at all and there was no question about which is best. The exa was described as the only one that did not give you the feeling that the computer is the source, the comaprison was done against a top Naim CD player, my ex Examplar 3910, a heavily modified Young DAC and even a turntable. I want to stress again that I feel that is best to decide between devices that you actually own, for me that is the only way to be objectively subjective. I know that audio is passion and we are not always rational, if you want to hear that the ExaU2I is not good you will hear it and vice versa, what is important for me is that it works flawless and sounds fantastic but I must admit that if there is a mK II with better parts I will get one 🙂 Hope that helps.
I also have had all the interesting dacs and interfaces through my system- Audiophilleos, M2HiTech, Emperical Audio, Metrum Octave, Lavrey, etc and the EXA U2I with a Buff2 and tube output stage is in another leauge. And being able to upsample to 352.8Khz and 384Khz is a big plus imo. Even well recorded MP3 sounds a whole lot better when upsampled properly- I'm using PureMusic and Audirvana Plus and it is as good as I've heard.
I'm building 3 more units for friends as once you hear this it's hard to listen to anything else again.
And it's very refreshing to experience personal service in these days of computer generated replies to customer service. George's accent is a bit tricky to an Aussie, but he probably finds my accent even harder to understand, nevertheless he's been able to help me overcome a few set up niggles with relative ease.
The U2I is a sleeper- watch it become the reference standard when the audio world wakes up.
