Converting Stereo Console into guitar amp with aux input.Need ideas
Hi. I have a gigantic 1970s era rca victor stereo console. It has a hinged lid with a turntable and tuner inside. I am replacing the power cable that broke off, and then I will see if it still works. I assume the electronics will still work, which will let me evaluate the speakers, which I assume will not work very well. It has been incredibly well stored, so it may all be fine.
My end result would be to convert this thing into a big guitar amp, by replacing the speakers and then the internal electronics with a nice guitar head. I would also like to retain its use as a home entertainment unit, by including a new audio input (for whatever - ipod, pc). Where would YOU begin?
I'd begin by making the decision between guitar OR hifi.
Both guitar amps and speakers distort in ways that keep electric guitars from sounding like what they really are - steel strings on a plank of wood. I suppose if all you listen to is Chuck Berry and Elvis, and you want to recreate the sound of a '57 Chevy radio at full blast....
Guitar speakers don't go low enough to reproduce bass guitar and they barely go high enough for vocals. What they do to cymbals is literally painful. Guitar amps are all about bass and treble boost, and to get a typical guitar amp (Fender, Marshall, etc.) "flat", you need to turn the bass and treble controls to near '0'.
On the other side of things, you can't use hifi speakers for guitar. The suspension is linear, and simply can't handle the dynamic range a guitar can produce. Nor are they designed to deal with the heat that distorted guitar signals produce. Same thing with hifi amps. No one "dimes" a hifi amp for hours at a time. They're meant to work up to their rated wattage, not far beyond.
Having said all that, I have spent quite a bit of time listening to music through guitar amps. The best rig was a home-brew copy of a Fender preamp running into a Dynaco Mk III with a JBL D130. Clean speaker, keep the amp down... it wasn't that bad, but then the cassette tapes of old Chess recordings didn't have a whole lot of fidelity to lose. ;)
Ok, a little more specificity. I am mostly outgrown of my need for a marshall stack. I have begun the process of opening up my console. It's a rca victor vft-76w. Its got some 12axt tubes. One channel is playing, one is not. I suspect either the tube or the crossover for the right channel is bad, but thats a shot in the dark. Each "side" of the console seems to have 4 drivers, a 12" and 3 similar sized appx 4" units. Probably 2 mids and a tweet or 2 tweets and a mid. The wood is showroom condition though. It's high quality and built like a tank.
For now, I believe I will begin the process of replacing the speakers. I will buy a couple of the dayton audio small amps to power them so that I can listen as I decide what to do with the 12ax7 based amplifier. I have no desire to use the original turntable and tuner, as the radio will turn on, but there is some serious hum right from the start even with the volume new. I would love to salvage the tuner, since big, smooth turning knobs are nice.
For now...can anyone recommend replacement speakers?
bass - its a 10 or 12 inch
mid - 3 - 4 inch
tweet 3-4 inch
Basically I am looking to create a high quality free air system since its basically a backless box. The wood the speakers mount to is removable, so im not tied to using the same configuration. I'd love any recommendations.
Administrator
Joined 2004
10 INCH GUITAR SPEAKERS from Parts Express ship same day and come with 45 day money back guarantee. Free Shipping Available. Order free 10,000 product catalog.
12" Guitar Speakers, Replacement Guitar Speakers, Instrument Speakers, Guitar Amplifier Replacement Speakers, From Eminence Speakers
10" Guitar Speakers
12" Guitar Speakers
Plenty to choose from there. Good for guitar, not ideal for hi-fi. Maybe you could put in a switch for tweeters to use when you want to listen to recordings. Sounds like you want it mostly for guitar, so build with that in mind.
Keriwena's post is full of good advice.
Well, i have thought it over...I am going to use it for reproduction, and just get a fender twin or similar for guitar. But now, on to replacing the 12ax7 amp...do you think a couple of dayton audio units would do the job? I wont play it loud, but id like good transient capability.
I am not totally sure. I'm kind of new to all this. It's a vft-76w rca. I will take pics tonight, and dig up the photofacts schematic. I was truthfully thinking about the 90$ class t, 50 wpc model, since its cheap and I think its going to take some time and money to sort the 12ax7 amp. I figure crossovers are going to cost me dearly. I was hoping to make up for some of the electronics costs by finding other "hidden gems" like the popular small tang band units. crap for the money of good passives, i could use a decent active, and run a ton of tri path amps, 1 for mids, one for tweets, run a monoblock for subs. I'm open to ideas though. I'm not a gear elitist.
Well, thats kind of where I'm at, replace the speakers (daunting), buy decent crossovers, add some small amp. Make it all useable while researching amp repair. The fact that it made sound at all was nice. If a tube is bad, is it usually visible? I thought:
1) Pull the bad channel's tube and look at it
2) put the good channel's tube in and see if it works
3) connect a known speaker to the good channel to see what the sound is like
would be good places to start dissecting the problems
Administrator
Joined 2004
Yes, that's the basic trouble shooting.
The $90 class-d amp is decent and should hold you for quite awhile. I use a little Lepai class-d in my old Fisher console 'cause the tube amp was gone. Works great, it's my TV speaker.
Why replace the speakers? Get it working first and listen to them, you might like them. Add a small resistor in series to mimic the output impedance of the tube amp. Maybe 2 or 3 ohms. Grab a few from Parts Express when you order the amp.
Well, I figured they were bound to be bad, at least some of them. I'm really looking forward to getting it set up, with itunes of course ;) It's a fond memory from my childhood, it was my grandparents. Still loaded with their LPs!
Oh, last night i notices there was a "tape" input. It has three connections, how do you hook up an external source to it?
Administrator
Joined 2004
On the tape connections there was often a loop for monitoring. Not sure why there would be 3, 2 is more common. (IN & OUT)
Photos will help a lot.
Also determine what size drivers you have and what will fit. That will help you choose if you need to replace. 10"? 12"?
Yes they are 10" or 12". I will do my due dilligence tonight and get the proper measurements and pictures. The tape thing was odd to me as well. I found a schematic last night and I will post that as well. I suspect faulty wiring may be a factor as well. From the looks of the inside of the console, I'll blow through a roll of nice wire pretty easy ;) It's interesting ot note that both sides have external speaker connections...4 screw terminals per side. I would think wiring more speakers in would cause problems (I know enough impedance/series/parallel to make me dangerous) either by lowering the resistance too much or raising it too much. Plus I am surprised to see externals for 2 speakers per side.
Ok both channels are working. there is a short somewhere that is causing the right side to cut out intermittently. How to isolate the hum though! I guess im going to need to replace all the wiring at a minimum.
Old gear like you describe often is not grounded, try turning the plug over in the ac socket, hum may be less.
Tube amps all hum slightly, if it is making a lot of hum the main PSU capacitors may be dried out and need replacing. The phono circuit has a huge RAII bass boost, make sure that it is not engaged.
The tape input may give you the overdrive you would like for guitar.
Below is a picture of the guitar rig I made from an old tube Nordmende Isabella console stereo.
The low speakers made good sounding guitar speakers, the amp distorts nicely at (relatively) low volume. The "tweeter" speakers reproduce stuff you don't want from an electric guitar amp, response much above 5K generally is not needed or desirable for electric guitar.
If you don't want to blow your ears out , 5-10 watts is all you need.
A Fender Twin is around 100 watts, by the time you get the output tubes distorting a bit, the speakers are hitting 120+dB.
Art Welter
yes I am going to work on the guitar aspect of this later, and for now, simply route my macbook into it and play guitar via guitar rig or something like that. For now, figuring out what needs replacing is the key. Progress is ok, considering my knowledge of electronics consists of knowing how to wire parallel or series to put several 4 ohm speakers on the same output but maintain the 4 ohms (from my old car stereo days). Love the glowing tubes though. I'd venture that decent replacement speakers and wiring will be a giant stride. There do seem to be shorts in the assorted dials, since huge distortion can be heard as you move them...treble, bass, volume, etc.
