Sorry, I can't tell you.
I am doing the job for another guy.
mhmmystery I like it
It may seem curious, but the more noticeable improvement is in the basses. Specially kick drums. More solid, less "one note", more fast and detailed. Separation is better and treble less aggressive (you can feel you have lost some of them). Of course all depend of the source. You can discover some saturation and clipping in CDs that you never noticed before, and an aggressive recording will sound more aggressive, while a good one softer. By contrast.Could you explain the subjective sound when you achieved 1000V / uS slew.
I would also strive for high slew rate but in practice I have found that slower can sound more pleasant and realistic in some ways.
I'm impressed too by the results. But the idea comes from you you. Did-you amaze yourself ;-)What you did to Crescendo is just simply amazing, I am impressed.
If the SSA was AC coupled with lower rail voltage it would make a PREAMP. There is no HISS...
Going to build this one.
@ dadod,Why yours circuit diagrams are always so big?? Not easy to check on line, need to copy first and this is not practical.
dado
LC LC for the HiQ of Yours SSA BiGBT version.
You perhaps already listen it for a while.
Could You pass some of Yours listening impressions for this HiRes HiPower SSA amp?
What speakers You drive with it or You maybe use a multi amp arrangement ?
- Would it'll be necessary to change much of the values for the IP and OP stage if the voltage
for the OP Stage would be + & - 50V DC (2x45V AC - CM500W trafo) and separate 60V DC for the IP stage ?
Kind regards
PCB will probably ended in a group-buy. Will see hehe
If there will be wishes like yours to adopt SSA BIGBT HP to different supply voltages, I will prepare all the necesary data, it is really nothing special, only a few resistors have to be changed accordingly.
Cheers, Andrej
