Please help ID this 18" woofer
Anyone know this 18 inch ? any use for home audio ?
thanks!
Hi Airegin
The cone and especially the basket both resemble the JBL 2240 but the magnet is something else. For a while there were many overseas Asian manufactures that openly copied the 2240. If it is a knockoff of the 2240 then I would be very cautious about using it as a HT sub woofer as it would lack the Xmax needed as it would easily bottom out on infrasonic signals, unless a low-cut filter was used below 30 Hz. For music it would probably be acceptable, however beware that many of the Asian woofers produce unacceptable (to me at least) amounts of distortion (lack of internal shorting ring etc).
Cheers
PJC
