It'll be a while before I get to it, I've got a few other projects to keep me busy in the meantime, but I've started thinking about trying to build myself a couple amps. I've done some diy electronics stuff in the past and I've been spending some time reading up on amplifier design and I think I understand well enough and have the requisite skills to take a shot at it. I have no desire to design an amp from the ground up, I'll be starting with a schematic and buying parts or maybe just buying a complete kit.
I've been looking around at AX84 and I like the looks of what's there. I thought the HO looked like it would be a good beginner/intermediate project. Complicated enough to teach me a few things as I go, but not so complicated as to frustrate me and end my interest prematurely.
At some point though, I might like to try a more advanced project (maybe more than one). The two that interest me most are the "October" and the "4-4-0." The october because it looks like it's got more sophisticated tone shaping circuitry and would make for a very flexible amp able to do a lot of styles. The 4-4-0 because I really want to hear what all the trainwreck hype is about, and I do like the idea of a responsive, touch-sensitive amp.
So what's the question? Well, I wonder if anyone has experience with these three or any of the other projects listed on AX84. Better yet, do you have experience with more than one of the project amps? I'd love to see some compare and contrast kind of commentary on the various builds from people who have built them. How do you like the tone, playability, responsiveness to different inputs, tonal variety, does the 4-4-0 live up to its pedigree? As far as the build, how would you rate the degree of difficulty. How much fine tuning is necessary after the initial build is complete? Were some kits more difficult to tweak than others? Any information is good information.
Oh yeah, one more thing, how would any of these take to a VVR-type circuit. I definitely like to open 'em up when it's appropriate, but as often as not, I need to pull my volume way back.
The AX84 site has designs that have been around a while and a LOT of discussion, so if you decide to do one of their projects, you won;t be alone. That's good.
MY advice to you would be decide on one and build it. Once you have that experience, you will be better equipped to make decisions on further projects and modifications. In my view there is no point in pkanning changes before you know what you have in the first place.
Building from a schematic is a character builder. Building from a kit can be just as rewarding, but the added advantage is that someone has already thought of what you will need. You won't get halfway through it and slap your palm to your forehead because you overlooked the need for - whatever, a fuse holder. Also, depending upon the level of kit you buy, if it comes with a chassis, especially a drilled chassis, that will be a lot of work and planning saved.
Enzo - Thanks, that's sound advice. I will most likely do the HO first though, I'm kind of torn between that one and the higher output SEL. It is not likely that I will ever be playing anywhere outside of my house, that phase of my life has passed I think, but if the master volume works alright it might be nice to have the extra power on tap.
One nice thing about the ax84 projects is that board and chassis layouts are posted on the website. I'd rather have a nice neat board than a rat's nest. I think for a first build I'll use someone else's well thought out layout and learn how to do it right. Maybe I'll be more adventurous later on. I do wonder how much I might save if I shop around for components and fashion my own board and chassis using the templates. What are some good places to find cheap components?
I'd still love to hear what anyone thinks of the various designs posted there.
For general parts, companies like Mouser are a pretty common choice. Or Digikey or Newark or Allied...
What those places won;t have is much tube related stuff. Likely no tube sockets, and alimited selection of high voltage electrolytic caps, and no tubes. They do have some transformers, but they will be generics like Hammond, not specific like for Fender Tremolux or something.
For amp parts, ther are a number of places, but one that is reasonable and has a good selection is AES at:
Antique Electronic Supply
A good selection of the sort of caps we use, and tubes and sockets. Not to mention grille cloth and speakers and cabinet handles and volume controls and and and. Oh and a nice selection of books too.
Go ther and request the paper catalog be sent. That way you can page through it and familiarize yourself with what is available. That is a lot harder to browse online. Online is good if you know what you want and want to look it up.
When AES has a dozen different 9-pin sockets to chose from, you can find one that mounts to the chassis the way you want, or one that fits on a pc board, or one with or without a tube shield flange. And if they come in both 3/4" and 13/16" - I made those up - and you have a 3/4 hole punch but not a 13/16 one, then it pays to get the socket that fits the hole your tool makes. Saves an hour and a half with a file.
Look at a kit parts list and find them at one of thoe supliers and make a list to compare prices. A bag of exactly what you need has a certain time saving value, at least would to me. Of course at this point in my own life, I am sitting in a commercial amp repair shop, so I could just turn my chair around and find everything I need to build an amp. Not patting myself on the back, just that we may have different needs while shopping.
Thanks again! I hope you don't mind if I pick your brain a little more.
So resistors seem easy. Certain resistors in the parts list have specified power ratings. I need to get resistors for those spots that can dissipate enough heat. Other than that I guess you can pay more or less depending on the manufacturing tolerances. Easy.
Capacitors are more complicated. For the big filter caps on the B+ rail and for the bias caps there is a voltage rating specified. I'm assuming this is a minimum specification right? So if the list calls for a 1uf/25V cap and I see a 1uf/400V for a $1 that's suitable? That doesn't seem too difficult.
What I'm really not sure about is this... in the catalog there are a lot of "special" caps that are quite expensive. The marketing language describing them refers to better or faster transient response. I'm assuming that these are useful when they are right IN the signal path... I guess for use as blocking caps and in the tone stack? I'm not too sure where I can get away with using cheaper caps and when I'd be better off spending a little more.
Everything else seems pretty straightforward to me. I'll just use the recommended hammond transformers. The rest is resistors, connectors, switches and hardware. Is there anything I missed where it's really worth it to select better quality components?
This is certainly true. In addition to the fact that I'm not too savvy about component selection, but I'd like to learn a little.A bag of exactly what you need has a certain time saving value
A lot of special caps are selling mojo rather than real improvements in sound. These caps are made by naked virgins out of spun gold, so naturally the soundstaging is stunning and the blah blah blah...
I won;t tell you there is no difference between caps, but think of it like tires for your car. If you want to drive to the store, does it really matter if you have extra stunning stability in curves at over 140mph? Or if the tire pressure is within a quarter pound of each other?
In my opinion, spending a lot of extra dough when you are just beginning is not warranted. If you are just learning to ice skate, you don;t need to look for $1000 skates like olympic skaters and pro hockey players might chose. Learn to skate, and once you have the background to know what differences in sound are there, then think about alternatives. Besides, if you make your amp with dollar parts and get used to the sound of it, then it will be real instructvie to swap those caps out for fancy ones later and hear the amount of difference it does or does not make.
SOmeone else may disagree.
Yes, you can use a 400v cap where a 25v cap is called for, but the higher the voltage, the larger a cap's physical size, as a rule. Caps have gotten much smaller than they used to be, so it may not matter, but a typical cathode bypass cap of 22uf at 25v is tiny and really cheap, so I think in general it will be unusual to find a 400v version of something that is cheaper than the 25v version.
I built up an AX84, Hi octane, SE amp kit for a client that bought one and
decided not to follow through with the build himself.
The result was one of the best sounding gtr amps I've ever heard, within
it's volume restrictions.
This amp is very sensitive to component choice. For example, I tried a few
different OP tube cathode bypass caps, even a Black Gate and they all had
a different sound.
I did change quite a few component types from standard, and used my own
grounding scheme.
Recommended. 🙂
Thanks guys. Definitely won't get too fancy to start with. 🙂
I was pricing components at Mouser and it looks like there's the potential to save quite a bit of money if I buy most of my components there, buy raw materials (garolite and aluminum) from amazon and just buy transformers tubes and sockets from AES. At mouser, for the most part, I picked the cheapest caps that fit the required values. These included some multilayer ceramic caps for the tone stack and blocking caps and tantalum rather than aluminum electrolytics for some of the cathode bypass caps. Is this too cheap? Are there capacitors that really aren't suitable?
I am always nervous around tantalum. They work and sound just fine, but they have ZERO tolerance for reverse voltages and don;t like overvoltages. As a pro audio repair tech, I cringe when I see them in something. But that is just me.
I have no problem with fancier caps, I always think about the caps physical attributes. If you build on a circuit board, then consider the hole patters, but if you build point to point or on an eyelet/turret board then I prefer to look for axial leaded caps. A radial leaded cap can have the leads bent out to either side to go to eyelets, but I'd just as leave have axial leads in the first place. Electrically it doesn;t matter.
There is more. It matters what they are made of. carbon composition, metal oxide, carbon film. Carbon composition have more "hiss" and noise but also slightly effect the tone. metal are quiet.
You are correct. Except that a 400V cap might be physically large and not fit in the space.
It's all marketing. How many days the strings have been on the guitar maters a LOT more than the brand of cap. Raise the speaker cap 6" off the floor has more effect. Basically you will never notice the difference. Even the very "clean" guitar amp sound, like maybe for a quiet kind of jazz player will for 20% THD. These amps are total "anti HiFi" devices who purpose is to create sound, not reproduce it. Would be silly to use a $20 coupling cap.
Hardware like switches, sockets and pots are what REALLY mater. cheap switches have a cheap "feel" and make the entire amp seem "cheap". Same for pots and knobs. Spend a bit on the user facing parts. Especially the input jacks. Go for the real-deal name brands eithe Cliff or Switchcraft, no generic Chinese jacks. Likewise put some time the planning in to the cabinet.
and you left out the #1 most important part: The speaker. Here the brand and model number really do matter. Much of the tone is defined by the speaker. But there is no "best". It's just whatever you like
Thanks yet again!
So are polyester film caps a safer or more reliable alternative to tantalum for this application? I replaced all the ceramic and tantalum caps on my shopping list with inexpensive film caps from cornell dubilier. If that's a better way to go it's certainly not going to break the bank.
ChrisA - I replaced all the carbon film resistors with metal oxides. Once again, that's not going to make a big difference pricewise if they'll be less noisy. I definitely get what your saying about the panel components. and I'll definitely take my time laying out and fabricating the panel. That's gotta look nice!
My speaker cabinet is one of the projects I need to finish before I start on the amp. It's intended for an ac4TV I bought rececntly, but if I get it done, I'll have something ready to go when the amp is finished. I'm building an open-back 1x12 or 2x10 (haven't really decided yet) it has to be 16 ohm to match the ac4tv output. What do you like for reasonably-priced speakers? I've had one recommendation to go with Weber sig-series. Another recommendation for an eminence cannabis rex (that's probably as much as I want to spend.) I play a wide range of styles. Anything but modern metal.
Depends on the tone you want. The last spears I bought was a 8" Weber sig. alnico (cost $36) because it has an authentic tone for the Champ replica I was building. Maybe you like or don't like this kind of tone? I think it's classic for blues and blues/rock
I also have a Eminence "Legend" 12", cost $100. It is more clear and detailed. Almost to much as every little mistake and fret noise and un-muted strings can be heard. This sound is more forward then weber sig.
Look at the Jenson "MOD" series for low price and a more modern sound then Weber and about weber's price. Better for an AX84 HO higher gain amp
A 1x12 or especially a 2x10 is going to be loud. Depends what you need I guess.
I bet you will eventually buy more then one and swap them around
I've been thinking about this a little more lately. I think my plan now is to make an open-back 1x12 cab, 16 ohm for my AC4TV. I'm considering the Jensen mods but I'm not sure which to choose. I like a nice thick sound, full in the low and mids, but still open or loose sounding, not tight and chunky. I want enough high-end for clean articulation and so that the high notes don't get completely buried, but I really don't care for a screaming, hot tone.
I've tried listening to the samples on the jensen website I just don't feel like the recordings are consistent enough to give me a really good grasp of the differences between the 4 different 12" MOD speakers. I think maybe the 70 watt is a little more scooped and the 110 has more of a cut on the low end. I think I prefer the 35 and the 50, but how do I choose? Can anyone tell me "theory-wise" what I ought to expect?
I'm sure I will, eventually. I think I'll make another 1x12 cab identical to the first one and wire them with a parallel output so 1) I have a way to A/B new speakers and 2) if/when I build my HO or SEL I can run it with 2 12s for "small club" volume.
- Live Sound
- Instruments and Amps
- AX84 kits
