The ES9018 SPDIF decoder is sensitive to errors. You have to be very careful with the grounding scheme and with potential ground bounce related to switching on and off of devices. Errors that many decoders simply pass along will cause the ES9018 to re-lock.
Russ, will I2S input solve this problem?
Thanks,
Angel
I would like to know the same - and if there is any IC to convertRuss, will I2S input solve this problem?
S/PDIF to I2S?
All the best, Salar
Thanks,
Angel
The core problem in these is generally related to mains wiring and sometimes DC on the mains.
Switching to I2S may or may not help. I have not experienced any problem myself for quite some time, because I found the root of my own problem which was a load on the mains that was creating DC. When I eliminated the mains DC I experienced no more issues.
BTW this is not unique to the Buffalo. I experienced exactly the same thing with the ESS demo board as well as other DACs.
Cheers!
Russ
A mains DC eater can fix the problem?
I have no idea. Because mine may not be yours. 🙂 In my case I simply removed the DC source and that indeed has removed any issues for me. It is the switching transients that the DC creates that are the issue, not so much the DC itself. So it is best to fix it at the source.
Intersting!
I have DC on the mains, used a capacitor-based filter first, later a 1KW Transformer.
But all transformers block off DC in the secondaries anyway, (the capacitor based filter and the 1kw ransformer only prevent the following transformers from mechanical hum) so how can this still influence the DAC?
All the best, Salar
All the best, Salar
Did your problems stop?Intersting!
All the best, Salar
This problem is not unique for the Buffalo DAc. Same problem with many other constructions .
Yes...
Typically these kinds of problems are caused by a DC spike on the mains, causing a momentary un-lock. I have heard this happen with a number of DACs.
DC spikes like this are often caused by poorly designed appliances in the home-usually something with a large motor causing a spike when it first turns on (or, perhaps off) like refridgeration, or AC motors. It is usually really tough to get rid of the "problem", and often requires replacing the offending appliance. Modern appliances in proper working order should not cause this type of problem. I do not think any AC circuit treatment is likely to get rid of the "problem" as spikes like this pass right through transformers, etc.
I´ll have to check again with the transformer, the D/C-filter did not help...Did your problems stop?
That is probably because it is not in the right place. The problem is that the EMI/Spike generated in such cases generally occurs prior to the DAC.
Barrows described it very well.
Synchronous Clocking
so far I am liking the sound of the B-II/Legato 2, synchronously clocked with the MC feed from my async USB receiver (I have Crystek CCHD-957s on the receiver board). The difference is hard to describe, but I would say perhaps the sound is more like music, and less like a digital/electronic reproduction-every once in awhile I also feel I hear a little deeper into the low level details-but that could be imaginary...
One problem though, I seem to have developed a ground loop between the USB board and B-II board? It is low in level (not audible even in late evening from the listening position) but still it should not be there.
Anyone know why changing to synchronous clock feed from the USB board (and de-powering the onboard iscillator) would result in a ground loop? All I2S grounds are terminated at the B-II GND input, and a single wire runs the clock to the R-17 pad.
That change alone would not create a ground loop. What you are hearing may not even be a ground loop. You may have introduced some longer wiring that could be picking up noise etc. It is a matter of working backward until you find the source of the problem.
Yeah...
Thanks Russ. After re-doing the wiring to be absolutely sure I did not have a poorly terminated ground somewhere, I still have the noise. The masterclock lead is just a single wire, so I suspect it is the culprit. I will go ahead and use coax wire for the MC and see if that gets rid of the problem.
Russ, could the upcoming S/PDIF 4:1 MUX/Receiver Module for BII be combined with a sidecar to switch between spdif and I2s input for BII, if sidecar is appropriately wired? Also could one wire a sidecar in a way that it will switch between 2 I2s inputs for BII?
Thanks!
Russ, Any answer to the questions?
Thanks.
Synchronous Clocking and hum...
I confirmed that the MC lead was introducing the hum into the output, disconnecting it and going back to the onboard clock eliminates the problem.
I have ordered some micro coax (U.FL) cables and jacks for the clock distribution. Russ, or anyone knowledgable here, is it advisable to connect the shield at both ends of the cable, or should I try just connecting it at the source (USB receiver board) end?
Thanks in advance!
Thanks in advance!
Hi all
I have ridden a BII with an output stage Legato v3. It sounds fantastic!
I'm thinking add a valve output stage. Something like "Minimax DAC PLUS". I think this dac does change through relays.
Please, I have a couple of questions:
- What is the disadvantage of introducing a relay (TQ2-5V) between the DAC output and input of the output stage?
- Is it better to use switches instead of relays? If the damage is the same, I prefer to use relays because the distance the signal cable would be shorter.
Probably best not to do this but I want to know what will happen if I do.
Thanks!
Al
Thanks!
Al
Many of you will be interested in this:
http://www.diyaudio.com/forums/twisted-pear/201106-introducing-bit-teleporter.html
- More Vendors...
- Twisted Pear
- Buffalo II
