exaU2I - Multi-Channel Asynchronous USB to I2S Interface
Greetings,
I have been perusing this thread for quite some time now. Exa seems to have an excellent product to enhance our DIY dac projects. I for one was on the verge of pulling the trigger on the +$400 product they offer. Unfortunately, their unethical behaviour in our community has haunted me and I've decided not to buy the product.
Compared to the TPA commercial prodcuts where they publish most of their product's schematics, I have yet to see the details of the exa prodcuts so we can DIY ourselves. I have never even seen any BOM nor schematic, not even a partial one. This is why I have been looking into alternatives such as audio-widgets and others. (If other members can enumerate alternatives, it would be appreciative to the community)
As I said, exa has a great product but their ethics for DIY community is questionable. It is obvious they are here for $$$$ gain. Unless they open up a thread in the commercial section, I will unfortunately continue to boycott their product.
regards.
If this was a product for DIY we would have 16 bit 44.1 separate L&R channels for the most DIY'd DAC in the world, the : TDA1541, I don't see this simple request ever being incorporated just the 32 bit LSB mismash, oversampled! LR data. No thanks. This is aimed squarely at the active driver/hometheater crowd and the few newbies smitten over S_D PCB's. Its like if Slim Devices started a thread here at DIYAudio when they developed the squeezebox.
As I clearly recall you may have serious memory issues,
Ray - I was referring to the posts by exa promoting his product or regarding exa's prouct posted by others. I was not talking about your posts. I have deleted many of your posts because I did not like the tone. If you post something friendly and truly useful on our forum I am sure I would let it stand as long as you keep the proper respect. 🙂 I have nothing against you personally.
I have few core rules that if violated result in deleted posts:
1) Be respectful and not abrasive.
2) Remember where you are posting and follow the DIYAudio core forum rules.
3) Don't post support questions on module threads. This is mostly because they just tend to get lost this way. We have a support forum for that.
In the end, if I think it does not add value to the discussion I reserve the right to moderate it out of the discussion.
I wish both you and exa well.
Cheers!
Russ
Regal,
The world has changed. Multichannel is not synonymous anymore with home theater and movies surround. There are fine audiophile grade multichannel recordings out there. Once you listen to proper multichannel sound stage, there is no going back. Very few people continue to deny that 44.1/16 bit is a very constraining format. We've been there, done that. It is time for something better.
Setting up a room for multichannel listening is difficult. You will need at least four speakers capable of delivering full frequency spectrum and dynamic range at low distortion. You will need to organize the room around the speakers. You may want to make them equidistant to the listening spot to avoid DSP processing. Of course you need a bit-perfect low-jitter interface and this is what exaU2I is designed for.
http://www.2l.no/albumart_full/2L060_box.jpg
Greetings,
regards.
Do you expect to be given the VHDL code for the FPGA as well ??
The dude is doing you a favour by pre-assembling the surface mount and fine pitch components on a properly designed PCB !!
regards
Trev
Seems like nothing would be lost if exa065 were to start a new thread in the commercial forum with a title referencing the exaU2I. I have no idea what it takes to start a commercial thread - are there requirements of some sort stopping anyone from doing this?
If there are no barriers, then the discussion of the exaU2I should continue there. Considering the cobwebs growing on this thread and the number of times it has been sidetracked, I actually think that a new thread would be preferred. Any stragglers who continue to follow this thread could be guided to the new thread via posted links. Not only that, but placement on the commercial forum could actually boost exaU2I sales again.
Everyone's happy!
Yes, it is about time for a new arrangement. I am considering several options.
I think it is good that someone is doing something different other than the same old run of the mill chinese ebay DAC specials which seem to consume pages and pages of threads on this forum !! Nobody complains about the free plug that they get on those things but here we have a dude who has put together something which obviously has had a lot more effort put into it than the usual run of the mill DAC and then he gets bagged for talking about it 😱
I don't think DIY audio or even audio is going to move ahead if people shun original thinkers 🙁
Indeed, and that's laudable. +1 exa065 🙂
Nope, he gets bagged for flogging it while keeping it on the non-commercial threads. Soundcheck is right, its overdue for a move.
Indeed not, moving the thread is by no means shunning it.
IMO he's providing technical support more than flogging it which is more than I can I say about the numerous threads on the ebay chinese dac specials which get a leg up without providing any support whatsoever !! I think there is an inequity here.
regards
Trev
actually i have complained several times about those threads =), including reporting them on occasion, i agree its insidious; at least EXA was upfront with his commercialism, why the thread remained here i'm not sure, especially after its been brought to a head over the last few days, but there was never any deceit on that aspect. i would argue that since the product already was selling before he opened the thread and asked for 'feedback', it should have been there from the first page. oh wait.... i said that on the first page or 2 and then a few pages later and it was insinuated i had ulterior motives of bringing down the product.
on the other stuff, why so dramatic? we only ask that this commercial thread go where all other outright commercial threads go and the appropriate payments be made to the forum like everyone else has to; not banish him. there he can talk about his products and actually have the legitimate right to tell people what should and shouldn't be covered in his sponsored thread. here i would argue, past politeness he doesn't as long as the topic stays on this device and others like it and there are a few popping up around the place now. one I've already mentioned; another i only just found out about, but i won't post a link here.
The china PCB's are being modded/tweaked in those threads, basically just used as a PCB to build upon. The schematics are typically posted and ideas roundtabled to mod, building completly different units out of them. Basically they are sold cheaper than the cost of the parts and a single PCB would cost a builder. Audiophiles have been modding store bought amplifiers since the 30's, it is very much DIY spirited..
This is completly different if you have read what is going on in this thread.
not all of them are like that, but you are right mostly. some (the ones i object to) are started by the companies themselves as nothing more than an ad and for sure they are making money, not all, but some use fake components on half baked data sheet designs and the pcbs are mostly about the last one you would want to do any rework on without lifting something.
modded or not you are still giving business to the dude on ebay and he doesn't have to pay a cent to this forum !! Good eh 😉
less business than digikey or hammond or mouser and espcially a pcb house. Are we going to move all hardware posts to the commercial section?
Your not paying for the design with a china PCB DAC just the hardware which is a platform to build from saving you the cost to build a one off PCB.
This much different than some proporetary unit that claims its digital isolators are better than a 4192to pulse to dig receiver. The Exa is a specialized multichannel/active speaker soundcard, great for that application. But the owner is misleading newbies into thinking it is a super low jitter i2s soundcard/computer transport for the buffalo or other stereo dac implementations is a streatch, the cat fell right out of the bag when the PLL PID had to be lossened up to get it to lock.
Not saying all the china pcb discussions are on the up and up but the lengthy ones where a completly different design is modified around the PCB are.
Here what you see is what you get, the owner defends his design at length and claims modding is wrong and unnecissary, this isn;t the diy spirit, it is a commercial design probably with a patent application.
The only difference between Exa and the dude on ebay is that the dude on ebay is getting a free kick whilst exa is forced into another section which is less relevant than this and now he has to pay for it. Doesn't make sense does it ??
If Exa is misleading people then why not debate it with him instead of moving the debate into a less relevant section that less people look at ??
I look at forums like avsforum.com and they have many vendor specific threads mixed in with other general query type threads. It's really no big deal to organize it like that. I don't go looking into the commercial specific threads looking for stuff on digital line level because I come here for that. Had exa been in that section I would never have known what it is that they do simply because I don't usually bother looking there, but I would certainly know all about the ebay dude from this section 😉
I don't know, typical guy comes to this forum spends $50 on a near datsheet DAC PCB from ebay and mods away with the group, that's DIY.
What is DIY about the EXA? The price we are paying for software and firmaware programming, the hardware certainly doesn't cost what he is asking. Is the software and firmware being modded by the group? Is it shared? Is it held secret?
I wish EXA the best, but its funny you mention the AVS board, much more appropriate peddling spot.
I'll get off my soap box, time to unscubscribe anyhow, Exa ain't bending on programming for the TDA1541 or R2R's. Just a S-D device , if thats what you need great.
Misleading the newbies
This much different than some proporetary unit that claims its digital isolators are better than a 4192to pulse to dig receiver .
Yes, we make this claim. Our users agree with us, some of those who never tried exaU2I bring un-quantified, non-factual criticism. We say that in our experience 108ps of getter (calculated, not measured) on the I2S interface causes artefacts below 140 dB on the analogue output of ES9018. Basically it is beyond what we can measure. Nobody has demonstrated the opposite. Subjective tests give us thumbs up. Correlation between measurement and subjective tests is the best reward for the designer. Do you know what is the jitter level on the interface that you are using?
The Exa is a specialized multichannel/active speaker soundcard, great for that application. But the owner is misleading newbies into thinking it is a super low jitter i2s soundcard/computer transport for the buffalo or other stereo DAC implementations is a streatch.
The exaU2I is equally successful in two channel and multichannel mode. For people interested in Stereo the drivers can route two channel to 8 outputs to allow for running DACs in a parallel configuration. The notion that somehow having 8 channel is degrading Stereo playback is again a stereo-type of the past. Looking at our client base - these people are hardly newbies 🙂. They've been around since the early days of the analogue sound, they are independent and experienced and they trust only their ears. They are still searching for the illusive sound and they are prepared to take risks and to innovate.
Now you are trying to mislead the audience. It has been established already that lock is lost because I2S involves frequencies that are 4 times higher than I2S, not because of Jitter. Are you seriously claiming that there is an SPDIF implementation that has less jitter than exaU2I?
Are you saying that all other I2S devices discussed earlier here on this thread are inferior to SPDIF in terms of jitter because they also experience lock issues when used with DAC settings optimised for SPDIF?
Are you suggesting to newbies that it is better to use ES9018 DACs with SPDIF sources?
Stereo vs Multichannel
Hi guys,
Let me get back to the Stereo vs Multichannel discussion. Personally, I listen to music sources in their original format - I don't derive rear channels from stereo recordings and I don't downmix multichannel sources. I try to minimize processing throughout the signal chain - analogue and digital - and to listen to recordings as they are made. To me multichannel should be given as much attention as stereo. There are enough audiophile grade multichannel recordings to justify the experiment. Ideally I want to be able to listen to any sampling rate / any lossless format / any number of channels the way they sounded in the recording studio. As a DIY person I want to do this on my terms. This is the only way to be in control, to eliminate unnecessary clutter, to get indulged in the exciting stuff.
To achieve audiophile grade multichannel is more difficult than doubling the speakers and the amplifiers. However the payback is really exciting.
Now that the Pink Floyd Immersion bluray disks are out, what would you do to listen to the Alan Parsons 96 kHz Quad mix of the Dark Side of the Moon? Have you listened to the Brothers in Arms 20th Anniversary edition in 5.1DSD? Both recordings utilize all channels at full rage. To get the complete experience you need at least four fully potent speakers and amplifiers. To me a fancy receiver and a subwoofer won't be able to get you there.
Should we reject multichannel because it is mostly occupied by movie sound tracks and gaming effects?
Personally I hunt for high-end multichannel recordings and I enjoy the "within-the-orchestra" experience.
exa065
