is Technics SU-V50 worth repairing...
Yeah, rip out the broken original very hard if not impossible to repair poweramp stage and replace it with a dx st or dx es or other poweramp of choice.
Thank you for all suggestions,
that was really what I wanted to do:
remove power section and use AN7062 as the driver of something like this.
Other option is mount fet Aikido preamp inside.
Thats not a schematic, its text file with the spice data.
Of course,
I thought that everyone in here is a beholder of LTSpice😀
Measuring current in ltspice is easy, just pass the cursor over a component and a current probe appears, then just left click the component to get a graph of the current.
fOr power, do the same thing but hold alt and a thermometer appears.
is there way to read static voltage and current in LTSpice?
Did you read that 3A was constant or sine through shottkys?
Maybe I made something wrong, passing over the part I got the probe and after leftclick got voltage on the graph, not the current...
Power measurement with alt pressed did not work:scratch:...
