Best sounding ECC83 ?
the blackburn ones
There is no "best sound" for any tube. Various ECC83/12AX7 tubes have different sound characteristics, while different people prefer different sound characteristics.
The Sovtek 12AX7-LPS have exceptional details in the mid-high frequencies.
NOS Telefunken have much "body" in the mid-high frequencies.
Really? No matter what the circuit they're used in, where the branded tubes originated, or when they were made (and hence internal structure)? Telefunkens have quite different structures depending on when and where they were made- the shape of the ink printed on the tube doesn't give them a common electrical characteristic.
Best sounding ECC83? That would be the one used properly. Not easy, as the high mu creates two problems:
1. It needs a high anode load, much higher than people often use.
2. There is only a small window in grid voltage between curved characteristics too near cutoff and the onset of grid current in the other direction. This window has to accommodate the whole input signal so the bias has to be right.
Given the right conditions it has a very stable mu so low distortion. The high mu means that Miller capacitance can be a problem in some circuits, but that is hardly the valve's fault as it has quite low Cag. Don't use a high mu valve then complain that it behaves like a high mu valve!
Also, I like extremely cheap chinese ones in a THICK glass envelope. They can sound just as transparent and wide spectrum as NOS mullard or flat plate telefunken.
All you need is to buy a bunch and do some pre-selection to sort out the most suited ones for your needs!
The most linear 12AX7/ECC83 I've tested were cheapies from an undisclosed location in Eastern Europe. Fat bottle, small plates (look like 12AT7). JJ were also excellent.
The ones with the small plates were RFTs, made in E. Germany. Wonderful tubes, I agree with you.
But I'm not much of a JJ fan. They may be fine when they work, but I had 50% failure rates when I tried to handle them. I couldn't afford to carry them!
