F5X from diyAudio Boards P-F5c-2V20e
It is a voltage clip.
The circuit has a gain of 6. So output is at 13.8V with 16V rails.
As expected not enough headroom left for the MOSFETs.
Since you are using 2 output pairs, you can increase rail voltage and reduce bias current per FET while keeping dissipation per FET below 32W.
I would try 20V 1.6A per FET as a start.
Patrick
Thanks Patrick
I thought about that but I use 22V Rails and 1.3A per FET.
Can you explain how you get the 6dB gain? With 6dB I get 4.4V out with 2.2V in. Wasn't it 15dB?
Your output voltage should not come closer than say 4V to the rail voltage if you want to avoid clipping.
The MOSFETs do not have sufficient Vds to operate properly.
Patrick
I understand that, but I'm missing a few Volts
Output with 2,3V in and gain of 6 (15,5dB) is 13,8V. With 22V Volt rail....
My PS is ultra stable. 800VA Transformer 2x18V, CLC with 2x99.000 uF, 2x 2,2mH/0,12Ohm.
Measurements and Waveform 1kHz 8Ohm
Amp info:
Vrail +/- 21.8V
Ibias 0.6V across 0.47 Ohm 1.3A 2 parallel output Fets Total Bias 2.6A
I out of PS measured 5.4A
NOT X-ed yet.
1. 8 Ohm 2.5Vin 0.5%THD right before clipping
2. 8 Ohm 2.6Vin 1.5%THD start of clipping
3. 8 Ohm 2.8Vin 4.5%THD clipping
Measurements and Waveform 1kHz 4Ohm
1. 4 Ohm 2.3Vin 0.6%THD right before clipping
2. 4 Ohm 2.5Vin 3.5%THD start of clipping
3. 4 Ohm 2.8Vin 7.5%THD clipping
It looks like the voltage displayed on your "oscilloscope" is Vrms.
The peak to peak amplitude is approximately 5 divisions x 8V = +/-20V approximately.
Assuming that is the case, then the input voltages you quoted are also Vrms.
2.8Vrms = +/- 3.96V Vin
3.96V x gain of 6 = 23.8V Vout > Vrails.
This should explain the voltage clipping which is clearly visible.
Reducing Vin to 2.1Vrms should give you, IMHO, the correct max. output according to your chosen rail voltages.
Patrick
First F5X Mono is running
I've got my first F5X up and running.
Sound is fantastic. All measurements are also fantastic.
THD is incredible low
Power is amazing
Amp Data and Changes made to schematic.
Design
Amp Boards X-ed as described at the beginning of this thread
Post #1
Amp Data
- Transformer 800VA, 2x18V per mono block
- PS CLC 2x 33.000uF 33.000uF 2.2mH/0.12Ohm 33.000uF; total 198.000uF per mono block
- Vrail +/- 21.8V
- Ibias 1.3A per output FET (gives 0.29V across R11/12), 2 output pairs! X-ed 4 output pairs
- output FETs IRFP240/IRFP9240
- input Fets 2SJ74BL/2SK170BL
- app. 70W into 8 Ohms, voltage clipping
- app. 130W into 4 Ohms, voltage clipping
- app. 175W into 2 Ohms, voltage clipping
- app. 200W into 1 Ohms, current clipping
R10 = 33,2k
R21/22 = 22k
R17/R18 = 702
R117/R118 open
R11/R12/R111/R112 = 0.22
That’s it.
Design
Post #1
Amp Data
- Vrail +/- 21.8V
R10 = 33,2k
R21/22 = 22k
R17/R18 = 702
R117/R118 open
That’s it.
I salute you!
I was told a Balanced F5 with the IRFP outputs would not work by some very visible people on this forum. I'm glad you proved it could be done!
