Open baffle woofer line array concept.
I've been playing with my new SEAS FR22 in a sealed box for a while now. And I really like the sound.
I am thinking of moving to the next step and build a OB for it. I intend to make it 2 or more ways by adding an additional woofer to it. I have two choices, either a
a) use a sealed box for the bass
b) Build an open baffle for the bass.
They will have separate amplifiers (with equalisation), since I don't belive any woofers out there has the same sensitivity as the SEAS full range.
Option a) is quite straight forward. Option b), the most commonly used speaker is the eminnence 15" beta/alpha etc, whihch I think the missus will not take too kindly to a 2 foot wide speaker🙁, even if I paint it red like a Jamo 909. An alternative, I am considering is to use 4 8" woofer for the bass (perchannel) in a line array, and reduce the baffle width to about a foot. From what I understand, the speakers should have an Qts of about 0.7. Is there any other requirement.😕
One driver candidate for this project could be this.
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=299-934
or
JAMO 20418 8" Treated Paper Cone Woofer 299-913
or
JAMO 20316 8" Paper Cone Woofer 299-939
This will be my first time building an open baffle, so any advice of any sorts would be very much appreciated.
Oon
I will most likely crank up the bass electronically for low frequency.
Trying to crank it up below Fs will easily lead to excessive excursion. Better look for low Fs (and some excursion) in the first place.
These are budget 10" drivers that worked well for me:
Visaton WS 25 E and Monacor SPP 250
Just check the parameters to see, what you should look for. Qts>0.7 is not wrong, if it does not signal poor driver quality. Try to have at least 3 mm linear excursion to each side - that's absolute minimum. 6 mm would be much better.
Any wall distance below 3 feet WILL be detrimental for various reasons. 5-6 feet instead of 3 will significantly help with the bass.
The problem with a narrow baffle is that it forces the c/o point for the O/B
to be higher that one would really want, only way round it to keep it low
is some form of active lower boost and the whole project becomes quite
complicated, ideally requiring measuring equipment, a least some serious
simming, and some serious active analogue EQ analogue c/o design.
See Linkwitz's Orion project for the sort of EQ needed.
http://seas.no/images/stories/prestige/pdfdatasheet/fa22rcz_appnote.pdf
Are you using an RL combo on the driver as detailed above ? If using a low
powered (valve) amplifier EQ is best done line level before the amplifier.
I've attached a sealed versus vented, 1.5cuft versus 2.5cuft comparison.
The very decent excursion of the driver, compared to the pathetic 1mm
or so of many 8" FR's, means its it capable of extended bass at decent
volumes, for low power (valve) amplifiers the extra bass efficiency really
can make a difference as well as the extra bass extension / max SPL.
Nothing against OB's, but IMO a vented floorstander suits the Seas 8"
FR the best. Very simple compared to the complications of a narrow OB.
Line level or passive EQ is a must to get a balanced tonality.
Relatively simple OB's do need to be wide for relatively simple c/o + EQ,
and TBH unless you need high volumes a smaller driver is best for 2 way.
A further option would be to build a 0.5 way, with an 8" helper woofer,
sealed or vented, if 4 ohm bass is OK and more SPL is wanted, but
that will ~ double box size, but reduce the driver EQ needed.
rgds, sreten.
http://sites.google.com/site/undefinition/diy (see FAQs)
http://www.zaphaudio.com
http://www.rjbaudio.com/Audiofiles/FRDtools.html
http://web.archive.org/web/20090902124715/http://geocities.com/woove99/Spkrbldg/DesigningXO.htm
http://web.archive.org/web/20090902202231/http://geocities.com/woove99/Spkrbldg/
http://speakerdesignworks.com/
http://www.htguide.com/forum/showthread.php4?t=28655
http://www.troelsgravesen.dk/Diy_Loudspeaker_Projects.htm
http://www.humblehomemadehifi.com/download.html
http://www.quarter-wave.com/
http://www.frugal-horn.com/
http://www.linkwitzlab.com/
http://www.musicanddesign.com/
Great free SPICE Emulator : http://focus.ti.com/docs/toolsw/folders/print/tina-ti.html
Dear Rudolf,
Thanks for the tip. I think the Visaton has real potential. The grand orgue and the petite orgue looks like both interesting project.
Actually I think my requirements for open baffle should be it should have a nice and narrow front, 12" would be good, and can be placed close to the wall (I live in an apartment). The grand orgue would have been nice, but since it can't be placed close to the wall, it is going to be a bit of a challenge.
Just wondering, I believe you have quite a bit of experience in this. What are the other alternative open baffle design that could fit my needs?
I am thinking of something like the petite orgue but I face the rear slot to the top and let it face the ceiling instead. That way I can have the clearence Either that or go with the slot bass
http://www.diyaudio.com/forums/multi-way/195734-nelson-pass-slot-loaded-open-baffle-project-21.html
Oon
Dear Sreten,
Thanks for your lengthy reply. The was originally thinking of it as a 1.5 way, OB for the fullrange and sealed for the woofer. But thinking more about it, heck, let's go all the way and see what this nice uncoloured bass that everybody is talking about sounds like. I have actually heard the Jamo R909 before once, and was quite impressed.
I already have other BR or sealed speakers, and I want this one to be a bit different. I was planning on doing some form of equalisation and power all the woofers with tripath class D amps. So that is not a problem.
The probelm is like the post befor ethis mentions... the space...😱
Oon
Actually I think my requirements for open baffle should be it should have a nice and narrow front, 12" would be good, ...
Having the front no wider than 12" should be no problem, but ...
... and can be placed close to the wall (I live in an apartment). The grand orgue would have been nice, but since it can't be placed close to the wall, it is going to be a bit of a challenge.
Even with a W frame (like the orgues) you would at least need 50 cm distance to the wall. The only exception would be to place the W frames parallel to the front wall:
attachment.php
If you manage to have them far enough to the sides, you would be in the dipole 8 (green radii). But now you need to have 50 cm free space where indicated in the diagram.
Dear Rudolf,
Thanks for the quick reply. It makes sense, Pretty much listening to the orque from the side rather than from the front. In which case I could potentially do it in an S-frame (half an orgue) Would be slimmer and higher WAF.....
Will think about it...
Oon
I use two of those. They are rather good, standing up to abuse (120w/ch) in rather large rooms.
I also tried plugging one 8" driver on a 12" square baffle into the other amplifier channel. Played music through a TH, then turned the other channel to the same gain. No bass, even on a 4th order XO at 80Hz. Lots of excursion, no actual output.
Turned the source up a bit, the 8" driver hit 10mm p/p of travel. Back to the TH, it was enough to make people feel weird in the adjacent room. Very low distortion.
I'd say it's a no-brainer.
Im always surprised that LilMikes Reed Exodus Anarchy tapped horn is hardly ever mentioned as as a possibility for this type of request. Very compact and goes down to 25Hz or so.
jamikl
Hi thanks for the tip, looks very interesting, the only reason I am not crazy about it is a horn. Would want to keep it as close as possible to an open baffle.
Thanks.
Oon
Sent from my Milestone using Tapatalk
Line level equalization and a lot of displacement to compensate for the 6dB/octave dipole roll-off where 8" drivers with 2.5mm of xmax aren't going to cut it.
Thanks, was planning on using 4 to a channel, to make up for the smaller diameter, so would have the radiating area of a 16 incher.
More likely to move to a slotted baffle possibly with a visaton another poster suggested with a bigger xmax..
Oon
