I think I scare a couple of my friends and follow the schematic as a P&ID 🙂.For someone who doesn't know anything about electronics, you're doing a pretty impressive job of these amps!
I build and my mate checks it for me ,but its better than buying off the shelf and you can go that extra yard with the design .
CHeers
The Mundorf - M caps was a gamble. I used 3 X 47 and one 100/500V. In the first 30mins. one shorted and took out the rec tube. Partsconnexion replaced it. Now all have been working for months with lots of use. The Silver Dragon has a REAL sound and I'm building myself one. And once again going for Mundorf film caps.Very nice looking 300B SET . How do you find the Mundorf tube cap's ,I've used the Tube Cap range in the amps .The larger SET is complete film cap supply and the smaller pair have a mixture of Evox,BHC and Mundorf Tube caps .
Lucas is a top bloke ,knows his stuff .Which is good because I don't have a clue about electronic's ,I think I scare him some times when my question's 😀.
Cheers
What did your amp cost in parts. The one I built cost $3.5K in just parts.
To build the 4 amps @8K . But theres alot of iron and most of it custom values .The Mundorf - M caps was a gamble. I used 3 X 47 and one 100/500V. In the first 30mins. one shorted and took out the rec tube. Partsconnexion replaced it. Now all have been working for months with lots of use. The Silver Dragon has a REAL sound and I'm building myself one. And once again going for Mundorf film caps.
Between the 2 midamps thers 6 power supply transformers ,20 chokes plus reg fil supplys .
The tweeter amps between them have 4 power supply transformers and 6 chokes plus reg fil supply's .
Mundorf caps ,a friend is the Oz distributor which helped and I had custom value resistors from Caddock in the TX & MS series some of the values I bought 10 of .
The 5mm copper plate wasn't cheap 😡 .
Lucas put alot work into the OPT's heres the Raven R1 OPT
A couple of construction shot
Timber case's need to be finished
CHeers
The mid section they will be running drivers are PHL
15" bass baffle
Sorry if I've gone off topic
CHeers
15" bass baffle
CHeers
@56oval: Nothing exceeds like excess. When you have this puppy up and going invite me around for a listen. Or just a look!
Yes, i am impressed too !!
I noticed the Raven OPTs have a 2ohm secondary resistance. If I get a chance I will compare it against the big Hammonds I used in the Silver Draggon. 2ohms sounds nice and low. We used 30W OPTs in my amp for a 7.5W output but had to use the bigger trannies so they could handle the idle current (98mA).
No prob's 🙂 .@56oval: Nothing exceeds like excess. When you have this puppy up and going invite me around for a listen. Or just a look!
CHeers
slim amps
Hi there,
first of my new series Slim Amps.
This is a 6EM7 with tube rectifier
also a solid state phone stage
next a 300B
the PCB'c are designed by me, the PPS can do tubes or diodes
the amp boards can be set up in many different ways, even headphones
Hi there,
next a 300B
And here is my First project 😀. Under construction.
My Aikido Parafeed headphone amp. I had it playing music on the breadboard
for 1.5 years but it took forever to get it cased up.
Tubes are 6CG7 RCA clear top and 6H30DR, boards are the first ones from Broskie with one
of the boards rewired to have a symmetrical layout.
PSU is all regulated with a Salas HV shunt for B+ and a LM1084-based reg for the heaters.
The PSU is in a separate case connected to the amplifier via thorougly braided wires
and XLR connectors (3 pole for B+ and 5 pole for the heaters).
Parafeed OPT's are custom wound C-core units from AE Europe in the Netherlands providing
two secondary taps for 300 ohm and 64 ohm headphones. Parafeed caps are ERO KP bypassed with a massive Richard Jahre Mica 🙂
My first tube project.
12B4A Preamp fully dual mono
More pics here: https://picasaweb.google.com/107819649978961501873/12B4APreamplifier?authuser=0&feat=directlink
- Tubes / Valves
- Photo Gallery
