I have one question, I use to see that the input capacitor is usually placed before the resistor to ground, in this case 10uF and 100k.
I can see in your design that you placed the cap AFTER the resistor to ground. Is there any advantage or disadvantage?
Placing it before forms a high pass filter, how does it affect if placed after?
Regi
Regi
Regi, if you check the datasheet you can see that Vin consists of two inverting inputs which requires no pulldown resistor. Bias current flows from the output of A1 and A2 via the internal feeback to the "+" input.
The first resistor is only a pulldown so the cap won't be charged if the input is unconnected.
the pull down resistor ensures the input cap is charged. Omitting the pull down resistor and disconnecting the DC coupled source allows the input cap to discharge, back to near zero volts across the plates.The first resistor is only a pulldown so the cap won't be charged if the input is unconnected.
If there is an AC coupled source, i.e. with DC blocking cap on the output, then omitting the pull down resistor leaves the interconnect hot at indeterminate voltage depending on the respective leakage currents and voltages in/at the two DC blocking caps.
Bump once more. Any practical experience/opinions?
I used 2 of your boards with LM regulators as a RCA to XLR converter on my B1, I had to use 2 independent transformers. When using the same transformer with 2 different power supply's there was a voltage difference between the grounds, when one of the boards was left "floating" (B1 or DRV134 board). If both where forced to be grounded to a star ground then it created noise. The only way we got out of this problem was to use separate transformers. Then everything worked fine!
Eric
have you tried using 2 different power supplies that share the same bridge/smooth cap after the transformer?Hi,
Eric
- Analog Line Level
- DRV134 pcb
