best oscilloscope for $100-200
if you can try find a philips 80s transistorized unit . 10MHZ will be fine for audio . i picked mine up a PM3233 for €10
edit . philips go go go . ever taken apart a blue front philips scope ?
Yes, actually. As someone who used to repair commercial test equipment for a living I am NOT a fan of Phillips scopes. There was a reason it was only €10. Phillips makes a classic error in their power supply designs. They use a limited thermal mass heatsink in conjunction with insuffient venting. So once heatsink saturates unit slowly overheats creating drift and early component failure. Okay for intermittant use but not to be used for 8 hour work shifts.
I had that very discussion with the president of Phillips at Wescon in 84. When I brought up their thermal drift problems he promptly shut up.
Doc
im still a fan course its made here 😀 and its out of callibration anyways . fixing the thermal runaway wouldnt be a problem for me if it ever occured . I'd stick a ATX fan on the back of the cast alu lid . and bolt it on .
You can actually improve one quite a bit by just removing the covers and drilling some 1/8" vent holes top and bottom to get some airflow going. Quite frankly at €10 I'd probably have bought one as well... but I wouldn't go to €50.
Doc
If you want small there are a couple of Tek 220 series 500KHZ portables on ebay for fairly cheap right now. (as of last night - sept 21)
Doc
I like that one, but I'm a DIY beginner (and a noob with little to no knowledge of electronics), I don't think it makes much sense to spend more than $200 for a device I very rarely need. Besides, expensive as it is - shipping that 220 to my country will make it cost like golden 🙁
Try a closer Ebay. If you want a real scope $200 is about the low end. If money is tight, it is better to buy something that is old but excellent than to buy something that is new but junk.
Doc
For audio work, I believe we want high sensitivity in a scope. I just bought an old HP/Agilent 1200A which has down to 100microvolts/div, whereas you'd be lucky to find something with 1mv/div these days. Most of the cheap scopes are only 10mv/div. It's also handy to have balanced inputs for low level signals, which very few scopes have these days. These kinds of scopes have low bandwidth also, like about 500kHz. We're not designing radios after all so who cares about that.
Are there any other options besides the HP/Agilent 1200A?
I would like to obtain a CRO with this level of vertical deviation resolution. I'll need to purchase one in a few days time.
(Sorry for resurrecting an old thread) :snoopy:
Doc
I will strongly disagree, mostly because there is not that many specialists worldwide, which can inspect old oscilloscopes.
It is wiser a young fellow to spent close to 300$ and to select one basic fresh Oscilloscope at 50MHz with two probe inputs.
GW Instek has also such models for beginners, with three years warranty.
For audio use 250MSamples is enough for measurements over the acoustical bandwidth.
The demanding people like me, they are forced to open further up their wallet due their higher demands, which is not related with audio applications.
