class A to class AB switch
Hello,
I have a simple question:
Most class AB amps are biased to operate in so called "class A" mode on low level signals. So for example lets consider an amplifier that would provide class A behavior for its first 10W. Is this limit dependent on the impedance of the speaker? It is current or tension limited?
Thank you
The class of operation is determined by the biasing of the amplifier stages, mainly the output stage. In AB operation, the output transistors operate in class 'A' mode at low signal levels and then gradually go into class 'B' mode after the transistors reach the more linear portion of their curves.
You can operate an AB amplifier up to 10 watts in 'A' mode but it may require large heatsinks on the output (and perhaps driver) devices and possibly heftier transistors.
It depends on the amplifier design. If the power supply can deliver the current and if the driver and output transistors can handle the 4 ohm load, the amplifier should be able to produce 20 watts into 4 ohms while operating in class 'A' mode. With a properly designed amplifier, the limit is the voltage swing.
Most AB amplifiers are not designed to operate in class 'A' mode above 1 or 2 watts.
Just enough to eliminate the notch distortion in the output stage.
edit :
No. That is not the case. The transition to class B depends on the standing output current.
To produce 10W A into 4 ohms requires 1.4 times the standing current and doubles dissipation.
To produce 20W A into 4 ohms requires 2 times the standing current and quadruples dissipation.
endedit :
Its current limited so it would be 5W into 4 ohms. Note even though you
have lower class A power, output stage heat dissipation will be the same.
A high bias class AB amplifier, as opposed to optimum bias aB likes high
impedances. A quarter A amplifier 10W A, 40W B into 8 ohms would
deliver 20W A into 16 ohms and never enter class B.
Conversely the same amplifier into 4 ohms would deliver
5W class A and towards 80W class B if it has a stiff supply.
Basically you need to drop rail voltages and increase standing current
for lower impedance, for the same standing output heat dissipation.
(You also drop rail voltages for a 4ohm amplifier if your
pushing the thermal SOA limits of the output devices.)
Heatsinking here matters.
A quarter A amplifier 10W A, 40W B into 4 ohms would
deliver 20W A into 8 ohms and never enter class B.
Going for quarter A into 6 ohms is a fair compromise.
About 1/3 A into 8 ohms and 1/8 A into 4 ohms.
rgds, sreten.
Class A bias is determined by the amount of current, a typical push-pull (complementary Q) output stage can deliver up ~ 2x the bias current "in Class A"
since the current is fixed the Class A power into 1/2 the load Z gives only 1/2 the Class A power at 1x load
if you want a larger (or even the same) region of Class A operation in Watts with lower Z load you need more bias current
Thanks a lot for your anwsers!
So this is current limited, perfect!
I asked this question because I am going to use an autoformer between my amplifier and a compression driver (active setup) to reduce the voltager the compression drivers gets and lower the hiss. The amplifier will see a higer impedance (for exemple 64ohms if I want to drop the level by 6dB on my 16ohms compression driver), and I was worried if I would still get the same amount of class A behavior...
i presume that all the above is some kind of joke ....
i cant understand why any one will overbias a class Ab amplifier to approach class A and then put in the midle any transformer that obviously will degarde signal quality, speed and bandwidth ...
then again the word HISS i understand as noise comming from tweeters ( wrong ? ) so if a system produces hiss you try to eliminate the problem before the speaker looking at amps preamsp eqs (?) or xovers that are conected in the system
sakis
IMO trying to find the source of the hiss would be the best solution. If the tweeters need attenuation then this should be done by passive (or active) filters in front of the amplifier. This might also decrease the 'hiss', unless it is the amplifier that is producing it. If the amplifier is the source of the sssssssss, then get a new amplifier.😉
Also the transistion from class A to AB is dependent on the ouptut current change or load Z, and the bias. Simply increasing bias in a complementary OPS is not a good idea. Too much bias will create distortion, more particularly crossover distortion due to Gm doubling through the current crossover region. Also it can lead to thermal instability, runaway, and then puffff....:flame: the magic smoke releases.🙂
Try reading up on D.Self's Trimodal amplifier.
It had Summer/Winter setting switch.
Summer = optimum bias ClassAB,
Winter = ClassA.
The earlier KSA50 clone PCB also had a switch to change bias. This too could be used as a Summer Winter switch.
I get some hiss even when the gain is at the minimum setting, and no source is plugged.
I am not sure what the source of this hiss is (it is a very good amplifier, anbd other are using it with compression drivers without issue).
I tried to fixe my power line (with a furman power conditioner) but without great success... Completely "fixing" my power linbe would be very expensive, and might not be the solution either...
So the autoformer looks like an easy enough solution, not too expensive, and would fits my amp quite well (it is a very powerfull amp)
by speed you mean slew rate?
I know my amplifier has enough slew rate to reach 20khz at its rated power (690W/8ohms), so it should be ok even with hier loads.
Concerning the bandwidth, I expect a good autoformer like these one would not reduce the bandwidth:
eBay - Achetez et vendez vos objets neufs ou d’occasion
What other degradation are you thinking about?
It is possible.You can put an amp into a deeper class A, but problem is in heat in output transistors. I love Nelson Pass adjusting bias current for 50deg Celsius. Yamaha's CA1010 has switch on front panel "NORMAL/CLASS A", but relay switches power transformer so main rails drops from +/-55V to +/-22V; electronic circuitry changes bias from 25mV to 280mV and output power drops from 100W to 20W /8ohm.
The Trimodal amp by Douglas Self has a switch exactly like the one described.
