Early clipping with JX Amp
Dear Forum Members and Pass DIY Experts
I did some measurements with my new JX Amp this weekend and see lower power and earlier clipping than I expected.
The JX is designed after my erlier XA Amp which was designed with the AXE1.2 spreadsheet for app. 70W at 7-8 ohms. XA amp had 3 output pairs (12 IRFP240 per channel)
Power supply info
Rail Voltage: 18,3V
99.000uF CLC
Bias "old" XA is 3.3A
AC current gain app 60%
The JX works with the same ps, AC gain (R24=714 ohm) and bias.
It is build with the boards from peter (see picture)
It is build with 2 output pairs (8 IRFP240 per channel)
The JX starts clipping MUCH earlier. It delivers only 49 Watts into 8 ohms at 1kHz with 1% THD whereas the XA delivered 68 Watts into 8 ohms at 1kHz with 1% THD.
The 4 ohm values are 25 Watts into 4 ohms at 1kHz with 1% THD for the JX whereas the XA delivered 51 Watts into 4 ohms at 1kHz with 1% THD.
All THD measurements are made with a HP Audio Analyzer.
My thought was that the JX can roughly be calculated as the XA. What is wrong here?
Schematics
With values / changes
Absolute and relative DC offset is low and stable BTW
Voltage R8 is 8.4V
Maybe your negative current limiters are kicking in. Try reducing R14's to 221
ohms and see what you get.
Thank you Nelson for chiming in here! 🙂
THAT sounds good. I'll try this later. Is there a reason why you set R14 so high? I see it is 100 ohms in the published AX schematics and I built my AX's like that.
I just see Aleph 3 was 100 ohms, Aleph 30 was 392 ohms :scratch1:
R14 changed
I changed R14 to 150ohms as I didn't have 100ohms here.
The result is a bit better but not really good.
I'll try 3 output pairs.
