100W Hi-Fi amplifier-Help!?
Hi all!:wave:
I designed this amplifier under this schematic (Figure 1). Now I want to do some changes to the schematic because we need your help!
For the output transistor want to use of komplementary a pair 2SC2922/2SA1216, because you have to change the schematic?
What else should I change the schematic to improve the characteristics of this amplifier?
thanks and cheers!!
  • Figure 1 (For).pdf
Well done.
the ratio of R4:R1 gives good symmetry of current balance in the LTP.
Change the emitter resistor Vr in the LTP to two accurately matched 51r resistors.
Add a trimmer (try5k) in parallel to R4 and use this to exactly balance the LTP emitter currents. The remaining offset will be the error in matching the LTP transistors Vbe + the error in LTP transistor hFE at the quiescent current times the difference in the base source resistances. You can reduce all of these to very low levels by selecting before assembly.
If the voltage across the LTP bjts are matched and the currents through the LTP bjts are matched then the two LTP transistors dissipate the same heat. Couple these two transistors thermally and the drift in output offset with warm up becomes quite low.
If protection T8 is triggered then T5 will be destroyed.
For the time being, do not fit any of the protection circuits. Learn how they work first.
Read up Baxandall's diode for a quasi output stage.
Then read about JLH's capacitor modification for the quasi. Leave space on the PCB for these few extra components.
Well done.
I must admit I go weak English, .. so please all show the schematic (Figure 1).
Thanks for your help and cheers!
Hi all!:wave:
If someone who has the possibility of a simulation done for this amplifier (according to the schematic) I'll be very grateful?!
I expect the other comments, do not worry they can be negative and criticizing!:cuss::eek:
In the end, what changes to the schematic need to do to connect the output instead of quasi-complementary pair of a complementary pair with 2SC2922/2SA1216?
thanks
