I am offering group buy for the same super compact upsampling Wolfson WM8741 Mini DAC PCB which was posted earlier. You can make your own high performance upsampling DAC using this PCB at home. The mini DAC has USB and coaxial inputs with I2S Data switching between the USB and coaxial. The DAC works from 6V to 7.5V 750mA regulated power supply. The PCB is a double-sided FR4 PCB. The PCB size is about 110 mm (l) x 60 mm (b). BOM, component layout and schematic for easy assembling will be provided with the board. The enclosure can be bought from RF connectors, Adapter, Cable Assemblies, Pigtail Cable, Tools, Wifi Antennas & Accessories. This aluminium enclosure is a perfect fit for the DAC board. The cost per board is $25 + $10 worldwide shipping. Those who are interested can PM with number of boards required. I will process the orders once I reach a minimum of 50. All members who are placing the order will be listed.
Following members are interested in the PCB
ANADIGIT - 1
markus22ch - 2
Need 47 more to go...
Got few boards fabricated in advance. Apart from those who had already placed their orders four boards are available for immediate shipping. If anyone interested can send PM immediately with full name, address, paypal ID and number of boards required.
There will not any any increase in the shipping charge even if two boards are ordered, it will be the same $10.
Hey, I would be interested to know what design this is, if it is a publicly available design at all.
And if not, would it be possible to receive the CAD-files for it in return for a fee?
(I know a PCB prototyper and would like to get it in a black/gold flavor.)
Of course I would not share the design if that is not intended and I would not manufacture it for others without explicit permission!
Hello, i do not know if this design is publicly available or not, i haven't seen one yet. The pcb cad files are not available for sale. This project is meant only for diy hobbyist to make and enjoy a high performance super compact dac.
Here are few boards which I got fabricated in advance and are available for immediate shipping. The components can be easily procured from ebay, farnell, digi-key, mouser, etc. If anyone interested can PM with full name, address, and paypal ID.
Hello,
This project seem interesting, but before to buying the circuit-board, i would like to see the schematic.
Can you posted it ?
Regards.
Frex
Can you posted it ?
Regards.
Frex
I have received my boards. Thanks.
Nice quality. I have already started populating them. One will be stock, the other for experimentation with Sallas regulators, transformers +N.Pass buffer like my TP Opus or with That1200 + buffer.
Hi Tassosk
Nice to read your results vs Opus.
Could you give us some informations about your tweaks (a little bit OT... sorry)
PM will be more accurate.
Hi korben,
For Opus, PM is preferred. For this dac, will take some time before I share my impressions, since my regular job is more than demanding. However this dac looks promising since it is highly integrated. And if I have to propose something for the second round of boards will be an smd clock that gives more options and also the possibility to select the upsampling rate for the asrc that now is fixed to 96/24. Finally, my dream will be an integrated asynchronous 192/24 Tenor chip 🙂
Mr. George Boudreau, Yoyodyne Consulting, Canada paid for one board. Five more boards available for immediate shipping in this set.
Hi korben,
Hello, you can still change the upsampling rate, just cut and isolate pin 27 of ASRC and connect it to ground and connect pin 22 of WM8741 to pin 23 that's it.
Three more boards are available for immediate shipping. If anyone interested can PM with full name, address, paypal id and number of boards required.
One fully assembled and tested WM8741 super mini DAC is available for immediate sale. If anyone interested can PM for details. Only the DAC module is offered for sale. Buyers has to get or make their own power supply. Linear power supply is best for this DAC. The DAC works on 6V or 7.5V 750 ma regulated power supply.
All PCBs sold out in this set. Members who are interested in the PCBs can PM with details name, address and paypal id. I will contact them as soon as I get the next set of PCBs. One fully assembled and tested WM8741 DAC module is available for immediate sale if any one interested can PM.
- Group Buys
- High Performance WM8741 Super Mini DAC with I2S Data Switching – PCB - Group Buy
