If the AC currents are equal (but opposite) then there is negligible modulation of the HT voltage, so you get a cleaner power supply.
The AC voltage at first tube anode, in case of line stage, is typically 1...2 Vrms.
If the anode resistor is 100 kohms, the AC current is some 10...20 micro amperes.
Assume we have a typical circuit where 22...100 uF electrolytic capacitor is used to filter the +Ub supply.
I ask: is there any sense to concenrate to compensate this 0.02 mA AC current ?
Apart from that, the AC-current of the 2nd triode depends on the load impedance as well, not only on cathode resistor.
Until the grid arcs to the cathode...
Yes, this could happen, but I have never heard or experienced. Have you ?
Yes. That's why I always include some sort of clamp (a diode or a neon bulb) between grid and cathode of tubes used that way.
Yes. That's why I always include some sort of clamp....
Interesting.
Please tell me more and in detail. What tube(s), what +Ub, etc.
Has this happened to you personally or have just heard this happening to others ?
12AX7 and 320V or so. I was doing preamp mods to help pay my way through school, and early conrad-johnson units were my bread and butter. I did a line stage rebuild with a topology very similar to this one for about a dozen people. Three field failures, which I traced to this problem.
I included a diode from grid to cathode in the phase splitter of my 5-20 for the same reason. I didn't want to apply 450V to the grid of an ECC83. If you have a valve rectifier than this is not needed, which is why the original Mullard circuit does not have it.
I see. What happened to the tube ? How did it damage ?
Shorted, grid to cathode. Diodes put in, perhaps a hundred amps and preamps built since then with protection diodes or neons, zero recurrence.
In reality, I use cheap 4007s. Ideally, you'd choose something with lower capacitance. For the ImPasse, I used an NE2- very low C, nearly ideal, fires at 65 volts so not quite as protective.
Thanks SY. On my mini console I am using two direct coupled CFs but I am using 5AR4 regulator so I suppose the diode would not really be required but it would be quite easy to put them in.
I used 1N4148. Low capacitance (which is partially bootstrapped anyway), easily able to handle the small forward current before the valves warm up. High reverse voltage should not occur except under fault conditions, and then it would be cheap to replace.
Example of grid-cathode protection diode:Hi all!
To be clear, give the show a schematic !!🙁🙄
It is very difficult to see why this sort of circuit could get the tube damaged without a diode.
There is a voltage divider at the grid ( 2 x 1M ), thus the maximum voltage can not exceed half of the +Ub. Also the current that could "burn" the grid-cathode connection is limited by 1M resistor.
Is this a bit over design ?
Probably. That diode adds almost 3 cents to the cost.😀 I would agree, the size of the resistors makes this safer (my failed units had 100k plate resistors), but at what point does the reliability get better? 200k? 300k? 200V? 300V? For a couple of cents, it is not really a big deal to have that protection.
In my experience preamp valves are at risk of grid-cathode arcing when the grid gets much more than 100V away from the grid. Doesn't really matter what the source resistance is, pretty much any arc is going to make a mess of your cathode material- its only weeny after all.It is very difficult to see why this sort of circuit could get the tube damaged without a diode.
And it could happen every time you switch on. Remember, this temporary overvoltage is not due to a fault condition but a design condition.
Probably. That diode adds almost 3 cents to the cost.I would agree, the size of the resistors makes this safer (my failed units had 100k plate resistors), but at what point does the reliability get better? 200k? 300k? 200V? 300V? For a couple of cents, it is not really a big deal to have that protection.![]()
Mainly I try to understand why such a robust metal construction like the grid of the vacuum tube can get shorted due such small current (0...4 mA) that flows thru 100...200 k resistor and grid to cathode.
I have always thought that arching needs essential amount of current to happen.
In case of tubes the current is minimal.
In case of semiconductors this is clear.
Arcing needs a voltage to get it started. The issue is electric field in V/m. Grids may be robust, but they are quite small and very close to the cathode - which is not robust.
- Tubes / Valves
- High-End preamplifier with ECC82!
