Acoustic reflectors and piston drivers
ask Markus for details
To dismiss the Audielity system as "stupid" without hearing one can hardly be fair. My experience as an audio engineer is that what may look bad on paper and in the anechoic response pattern may sound great to the marketplace. It has made Mr. Bose very rich.
I bet they sell a lot of them along with those $1000.00 per meter cables that do nothing more than make the cable maker rich.
I was quickly looking into the acoustic lense idea. Here's the 8" fullrange speaker "naked" and playing through a 5 cm thick Basotect board mounted directly in front of the driver with a 5 cm hole in it (0°-30°, 2nd set of curves offset by 20 dB):
Quite encouraging!
Hello,
That would be the stereophonic artefact of pin point imaging of the tweeters that do not happen in real life. The image split in two. Very unrealistic. This only happens when the directivity in the treble range is too high, like horns and waveguides.
Isn't it rather absurd, that there would be people who didn't want the speakers to disappear, like they wanted to listen to the speakers instead. Are there such people, really.
And those people in the studio listening to the tweeters of the high directivity monitors keeping their fingers on the buttons to make recordings we have to settle.. Aren't they more interested in listening to the sound rather than the speaker?
- Elias
I've designed a lot of studio monitors in the past and most had higher than normal directivity, either through CD horns or dome tweeters with directional flares of some type. I generally like the higher clarity that comes from increased directivity, but I also ran across a number of people that really don't like the aspect where you can close your eyes and say: "all the sound comes from here, and here" (pointing at the tweeters). Those types want the speakers to dissapear and the sound to come from anywhere and everywhere.
Updated measurements now including vertical polar response:
Demokrit Measurements
Here are some measurements of the study object in post 1.
I'm building this speaker for certain reasons documented on my web site. For that it is easy enough and should suffice. If it turns out to be a good speaker, great. If not, I have a big basement 🙂
Amongst these reasons are the following, which are spelled out in more generic terms on my web site:
- Is 360° radiation constant directivity desirable or is less better ?
- If less is better, where should the response start to roll off ?
- If it is not better where is the minimum that will be good enough to create what I want from a speaker for recreational listening.
Have fun !
Oliver
Hello,
- Elias
Maybe the speaker is not to blame, but the recording engineer who panned the signal to one speaker.
I don't blame the engineer since I'm a nice person and respect humanity :angel: 😀
It is the uncompleteness of the stereo system as such.
Typical problem in stereo triangle: Singer (maybe female) panned in the center, mostly ok when pronounsing vovels, but when it comes time to sing "sssssshhhss" image is no more in the center but split in to two located at +/- 30 degrees at the speaker positions.
The best stereo triangle can do. sigh.
- Elias
- Elias
Quite honestly that is not what most people perceive. I've heard that very few people do have problems perceiving phantom images but it is certainly not typical.
