Need help idetifying this 50k pot!!!
Some quick thumbs of the pot...
The chip amp has a DC volume pin. The same pot can connect to each channel's chip amp. The pot adjusts the DC voltage on each pin, likely over ~5V range, and this sets the volume for L & R. The sub may have a similar chip amp, or it may use its pot in the conventional manner. It's likely that the sub pot is after the summing circuit and it is a single-gang pot also.
It's probably not the pot you want for your project, unfortunately.
