Planned finish date is mid-September.
This was partly due to delays in the drawings because of my family time-out in July.
I have a planned trip to Hong Kong end of September.
Depending on if you want, I could delay the shipment for 2 weeks so that I get to inspect and sign off the parts before shipping to you, even though I have full confidence in Mark's quality control.
The test team is busy with work, even though they have all they need to start building.
Many of us have to make a living outside audio.
Patrick
Patrick
Thanks for the update Patrick.
I too have been busy at work, which really slowed down my progress with matching the Fukushima resistors. I am happy to say that I just (a few minutes ago) measured my last 0R22 resistor! =)
Thanks for the update, Patrick.
Congratulations, Horio, it's good to learn that you're finished. Now, it's soon my turn.
I have two questions for Mark Lai & Patrick:
- Are your cute JFET heatsinks still available? They are described here:
http://www.diyaudio.com/forums/group-buys/135359-toshiba-dual-jfet-heatsink.html
Might it be possible to include some of these with the cases? Another (fast) GB perhaps?
- When do you expect us to make the second payment to John?
Thanks!
Thanks!
Does that leave the 0R47's still to do?
Yes.
- Might it be possible to include some of these with the cases?
I suggest you wait for the test team, because you might want to build one of the cascoded versions in the end, and they would need special solutions for JFET heatsinks.
Some time mid september.
Patrick
Yes.
Patrick
Conrad Heatsink Update
I have an update from Julian at Conrad Heatsinks,
Unfortunately he is running behind schedule due to being down 2 people.
We are now looking at mid October for completion.
At this stage the jig is set-up, he will run an initial set to send to me, I will confirm fit with an actual finished case from Mark.
Things are moving closer, a little more patience and we’ll get there.
Further Heatsink News
Julian from Conrad has lost two employees, he’s doing his best to get through a heavy workload.
His latest response as follows,
Hello John,
Confirming my call that your prototypes will be ready the week beginning the
17th October, and when they are approved the balance of the order can be
made within a week. My sincere apologies for the further delay and thank
you for your patience.
With regards,
Julian Wales
Just to confirm I have talked via phone, he his generally very sorry, this is not his normal work practice of promising and not delivering, but due to unforeseen events the heatsinks are held up.
I hope you all understand, sorry for the bad news folks, we just need to extend our patience a little bit further.
Hello John,
With regards,
Julian Wales
I hope so - even if I am on the list - I would love a second one🙂Wil there be a new case batch for all unlucky people that where not on the 25 list?
There is just one problem - when I put it next to the rest of my gear this will look terrible🙁
I hope Patrick will skin a matching pre-amp cat in 2012😎
Nic
Also my hope!
Uwe
Yes, I have a preamp case design, plus mono-block mini tower design, plus a SD card player.
But I do not yet have a good preamp circuit for the F5X.
My preamp circuit is for a unity gain all JFET circlotron (too much gain), and it is yet to be built.
But let's finish one at a time. So F5X first.
Whether there is a second batch for this F5X case depends on :
1) How busy Mark and I are (there is a high amount of work even only for a repeat) ?
2) How is the response when people actually have the case in their hands and whether they are happy with what they have ?
Patrick
Patrick
Patrick
I would appreciate it 🙂
I am also interested in a preamp chassis. I would also like a chassis for a DAC / CD, however this should just be a different front panel and read pannel.
There are enough chasses on the market if you just want 6 plates (even of various design).
If you want a total solution, like the F5X, then it has to be based on a circuit and a concept.
So it is not as simple.
Patience, 😉
Patrick
Patience, 😉
Patrick
- Group Buys
- Potential EUVL F5X designed case user distribution check
