Can anyone Identify this tonearm??
Can anyone Identify this tonearm?? there are no markings on it.
it is missing part of the bearing assembly and the headshell. but I am curious what it is??
Zc
SY is correct, I've owned at least 3 of these tables. Arm is not as bad as you might suspect, although my approach always was to replace it with something else..
I've had two AR turntables, the first I purchased in the early 1960's. I'd say the arm is probably as bad as you might expect: in the winter the arm required a 15 Watt light bulb next to it to keep the bearing from freezing up. Then there was the 15 degree tracking angle -- azimuth -- for which there was no correction. It didn't help that the suspension bottomed out and that the platter spun counter clockwise, but that at least was not the tonearm's problem.
