Hi all
Im trying to locate where I can find some parts for my amp. One part seems very difficult to find. It´s a "semi tube rivet" that I want to use when making a inlet thrugh the wooden schassis to enable setting a fixed bias. This "semi tube rivet" would schield the hole and guide the tool to set the bias. Anyone know where to find such a thing? Also, Im trying to find some kind of testingpoint that could also be fitted thrugh the top plate of the schassis....
Cheers
Cheers
Also, I'm trying to find some kind of testingpoint that could also be fitted through the top plate of the chassis...
Mouser has a ton of them.
Mouser Electronics - Electronic Component Distributor test point
These might work for you.
How do you plan to mount the bias adjustment pots?
The pots are mounted on a PCB so I will mount the PCB on the inside of the schassis. The part you found could work but I think something thinner aprox 4mm diameter.Where did you find it?
Hey! Thanks, they will be fine.
Cheers
