"DIY 1.5KW Bipolar Class-H"
Yes, but then you cannot use 2sc5200/2sa1943 pairs, because its breakdown voltage is 230V only and with 75V step the total voltage reflected would be 225V gives very little margin better go for 250V rated transistors if you want to increase the rail.
Thanks workhorse!
work with 18 "speaker 8 ohms each in parallel 800wrms. 2homs Total 3600w rms. I really enjoyed your amplifier. What tension and how many transistors in the output to work? The transistor output can be separated from the card drive? Sorry my inglish. Greetings!
I am looking very powerful amplifier. After several attempts. I decided to try to build 1K5 Workhorse.
First difficulty is the double-sided PCB. I resolved this by building two separate PCBs and then unilateral.
