I am starting a project consisting of two Hivi D6G woofers, a Vifa M11MH-09, and a tweeter, which I haven't settled on.
I like the Vifa XT25, however they only sound really good in a direct line as they have rather poor dispersion.
Then I saw the Vifa XT19 tweeter, which is similar but smaller. Looking at its graphs, its got considerably better dispersion.
I plan to cross over to the tweeter at about 3K, as the Vifa mid has a very smooth response and is well within its range.
https://www.madisound.com/store/product_info.php?products_id=1181
https://www.madisound.com/store/product_info.php?products_id=1179
Has anybody here used the XT19? If so, what are your thoughts? Also, if anyone has any suggestions on a good performance good value tweeter. I like 3/4" tweeters and might also look at metal domes, as I think a well implemented metal dome just sounds awesome (but as I said, needs to be well implemented or they can sound nasty lol). I don't have a lot to spend so will be looking at tweeters in the $60 and less bracket, unless there is something of exceptional value.
I think a 3/4 would be preferable due to dispersion characteristics, and the higher crossover point is not an issue. Any ideas?
My preference is easily the XT19. I had it crossed LR2 @3K in a 3-way for some time. It easily outperforms the XT25 unless you need the extra extension as you might in a 2-way. In a 3-way, I'd say to go with the XT19.
Dave
Dave
XT25 was a kind love and hate relationship to me
I liked it, but not without problems
XT19, I can't think of anything to say against it
sweet and natural
I think XT19 also was best performer in a distortion test, together with a Hiquphon, some time ago
sweet and natural
I use XT25G (that I just got from hasaudio in unzud for a very good price) in a 3 way crossed LR4 at 3k in an active setup. They are a big improvement over the DT25 (or 27) Vifa's that were in there, mind you, they were 22 years old.
Frank
Frank
+1 on the 25TG. I've had em for a while and I like them. Perhaps it's just me being a goofball, but they seem to be fairly detailed without being overly analytical, and I still haven't made the crossovers properly.
I think I will go with the XT 19, unless I see something else. I have always preferred 3/4" tweeters over 1", and since I will be using a relatively high X-over point I think it should do the job nicely. Another deciding factor for me is that one supplier in NZ (HASAudio) is selling them on special for $39 NZ, which is about $30 US.
I have not been able to compare XT19 vs XT25, but I do have some later model NE19VTA-4s that I plan to use with RS-52 2" mids. I recommend you have a look at that tweeter. You can find some measurements and a review on Zaph's web site (and also do comparisons with other tweets there).
Yes that is another tweeter I have seriously considered. If I dont go with the XT19 I will probably get one of those. I'm looking for something with good dispersion, that will have good clarity and sparkle, while not sounding harsh or fatiguing. Im assuming you have listened to them, how do they perform? Not too harsh sounding?
Also for me I would have to buy a pair from Madisound and they charge heaps for freight, whereas I can buy the XT19 locally. How many of the NE19VTA's do you have?
Only by substituting it into an existing loudspeaker; never a complete design. They sounded promising (acknowledging that this method has obvious flaws).
I have 5 (for a set of HT speakers). I was fortunate to be able to piggyback onto a fellow DIYer's puchase, saving some postage cost.
Thanks folks for all your input. I was leaning towards the XT19, and you guys gave me the final push, so XT19 it is. After this build, I will be looking at making some small 2 way bookshelf speakers using the NE19 tweeter as its small faceplate would be great for compact systems.. Most likely the NE19VTA-04
Sorry to drag up an old thread, but the XT25 looks great on paper with a low fs and smooth, extended response. Just wondered why can't it be crossed low?
I realize how late I am in commenting, but I used the XT19 in two builds and it's a great sounding tweeter. It's smaller radiating diameter gives it better dispersion than typically from a 1" radiator, plus is can be crossed at 2.5 kHz without stressing it.
Paul
Paul
It can, but HD increases quickly, so depends how much you're willing to accept & higher order filters will be needed if crossed over low. Zaph for e.g. strongly advises not using them < ~2KHz LR4 (or < 2.5KHz LR2) for this reason. Others disagree, but it depends what you're up to with the filter. YMMV.
Frank
Do you mean the D27 that PMC use in the IB1S ?
- Vifa XT25 vs XT19, which one to use?
