Hi Guys,
There seems to be a fundamental misunderstanding about power output and available voltage drive. When you say that you're using a 68W LM3886 based amp to drive the headphones, keep in mind that that the output power is specified for a 4 ohm load and +/- 28V rails. If you then hook a 150 ohm set of headphones up to it, the most you'll ever be able to get is about 2W. You'll voltage clip at about 16.5V RMS while delivering about 110mA RMS of current.
If you use the BAL-BAL version of "The Wire" with 22V rails on the LME49600, you'll be able to swing closer to 26VRMS which would be about 175mA RMS into a 150 ohm load. That means "The Wire" would be able to provide about 4.5 watts for those headphones, over twice what the LM3886 can provide.
It's important to understand that with high impedance loads, the output voltage swing is what will most likely limit the output power. If the LM3886 amp you have now drives them well, then "The Wire" will drive them even louder if needed.
Owen
Thanks for clarifying.. I was thinking something like that must be happening, but I was wondering where to look.. (I guess the spec sheets would have output power vs impedance)..
In that case, I think TheWire might make a lot of OrthoHeads very happy..😀
jdkJake:
Thanks for the excellent write-up and pictures! All feedback is very much appreciated.
You did a great job on the soldering, and it looks like you've got everything up and running as it should be. If you're running SE inputs, then you will be more prone to having noise pickup issues. You'll have to be cautious with your input and output wiring and shielding,and you can always try to BW limit by lifting the BW pin on the LME49600.
There are also some simple mods you could make to the BAL-SE board to bypass the first diff stage and feed your input directly into the second stage op-amp. You'd have to populate a few 0R resistors, and tack your input wires onto one side of an 0805 resistor. I can post the instructions for this if it's of interest.
Thanks again for your feedback, and congrats on another successful SMD build!
Owen
Thanks for the kind words Owen.
I would very much be interested in see the mods you describe, however, I am on the fence if I will make them. The performance of the amp is very, very good as I have it now and I really think I might try a balanced source in my future. Time will tell.
In regards to the power supply, while I have yet to instrument it to see it's actual performance, it's subjective performance in this application is very, very good.
A big point most are missing is how cool the unit runs under load. This makes many, many casing options possible. I have had it running most of the day and took some thermal measurements. At a room temperature of ~77.8F/25.4C I am measuring only ~103.5F/39.8C at the top of the regulator, on the heat sink, right above the screw hole. At the top of the heat sink itself (center), I am measuring ~98.5F/36.9C! Hell, I've had past girlfriends that weren't that hot! ;-)
Anyway, my point is, for the majority of the folks, the supply seems ideal for this app. There are of course many, many other options available, but, I would rather see Owen spend his time on the amp portion of the build.*
Now I just need to figure out how to get one of his balanced DAC's to pair up with this beast.*
well Joel, according to wikophonia they are indeed very inefficient orthodynamics!!!, but if you are giving them that much power you are driving them well past their safe max levels. according to the manufacturer they can handle up to 35w amplifier (which they probably dont intend you to crank all the way) and if you are giving them 2/3 of nearly 140w, well..... so either your amps arent as powerful as you think, or you are killing them.
. i mean this little amp will have some serious kick, but those headphones are what i would term by today's standards, a flawed design.
you may say this headphone has flawed, or irrational design..but the truth is, i have tried Hifiman HE5-LE, Audeze LCD-2, and Sennheiser HD650, and the only headphone that considerably outperform my wharfedale is LCD-2, which is priced four times of my wharfedale..after i told you this maybe you'd a little understand why i'm not letting go of this headphone whatever happens 😉
Hi Guys,
Owen
opc, thank you for chiming in my discussion..
when you were explaining those output power of "the wire", i assume the wire's gain were set to 1?
yeah good point owen, i was just going by listed specifications and warnings, which do not have much detail, a good reason not to do such things. does not efficiency come into the equation though? there are 150 ohm headphones and 150 ohm headphones, this was the reason i took for the discrepancy in recommendations. i realize the load effects the output, but i took there to be overiding factors that meant a standard ohms law or joules law could not be aplied without knowing them
hey i'm not saying you have to get rid of them, i was only suggesting perhaps get some others, i know the irrational love people have for their headphones, just look at how thunderpants came about. didnt think much of the lcd-2 tbh, just illustrates the variance of taste. i think they are very accomplished. fast, open etc, but not as dynamic as i prefer. i believe hd600 is more dynamic. which i by no means like over al other headphones
Hi Owen,
Could you update my order to the following?
1 BAL-BAL Kit & 2 BAL-BAL PCB
2 BAL-SE PCB
3 SE-SE PCB
So in total 1 kit and 7 bare PCBs. Thanks!
2 BAL-SE PCB
3 SE-SE PCB
@opc: owen, why do you use aluminum polymer in C9, C10, C23, & C25? will it provide similar performance if i were to use aluminum electrolytic in that place?
Hi idjoel2000,
The polymer caps have significantly lower ESR, and better frequency characteristics than your average aluminum electrolytic. As for performance, I'd be inclined to say that electrolytic caps aren't quite as good, but I'm sure some here would argue with me.
Judged purely on their technical merits though, they are significantly better.
Owen
Owen
Hi idjoel2000,
Owen
i see..
the thing is, if i ordered the wire pcb only, i can't get 16v rating polymer caps here in farnell (my only local source). hence i thought if polymer caps are similar to electrolytic, i would just use electrolytic
now that you mention it, i have to find another source to get 820uF 16v polymer caps
I'm in:
1. Full kit
2. PSU included
3. BAL-SE, BAL-BAL and SE-SE
4. One unit of each (1x BAL-SE, 1x BAL-BAL, 1x SE-SE, 3x PSU)
Thanks for all your efforts,
Doru
1. Full kit
2. PSU included
Doru
I spent a lot of time listening to this amp this weekend. I really like it. I think I want to see how small I can pull off an implementation.
Owen, put my down for a SE-SE kit with PSU.
Thanks!
Thanks!
Thanks!
jdkjake, have you tried the wire with high impedance headphone? how do you rate them compared to other amp?
high impedance headphone usually requires high gain with low current, while the wire is the other way around. i wonder if the wire is still the best for high impedance headphone
Hi Owen, can I change my kit request to 2x SE-SE kits instead of BAL-SE. It will save me from having to acquire a balanced source. Cheers!
Hi Owen,
How do you like your M-Audio Fast Track Pro? I have a Fast Track Pro (which I'm not using at the moment) and am wondering if it's worth adding a BAL-to-SE kit to my existing pre-order (for SE-to-SE) to try it out. (The FTP is my only balanced source at the moment.)
definitely use polymer if you can Joel, owen, i would suggest perhaps the panasonic special polymer range. smd, but large easily soldered smd, seriously high performance caps, but as with lots of polymer not always available in high voltage and high capacitance
the kemets polymer tantalum are good would be particularly good for the first stage, especially if we can supply a lower voltage here vs the buffers. could limit the opa1632 to +/-6v easy and still get good performance and then the whole world of bulk low Z caps comes into view. like 100-220uf caps as low as 5 miliohms
probably to late for suggestions like that, but for local supply caps bypassed with np0, or polyprop they make a great combination.
man Joel i pity you having to use farnell, you could order from mouser, or digikey and easily pay for fedex shipping with the money you save, and i mean easily!! farnell are the biggest bunch of wroughters around; often charging 300-400% and higher markup over digikey and mouser.
@qusp: thank you for your concern 😀
@opc: owen, for the BAL-BAL version, can you design the output to use 6 poles balanced jack? (+, -, ground, on each channel)
that way, i can easily turn the balanced output to single ended using converter whenever i want 🙂
I tried out my HD-650's and the amp sounds just fine. Remember, I bumped the gain to 2 just so that I could drive those phones. There seems to be plenty of voltage swing.
So far, I have spent the most time using my HF-2's. The sound on those is quite impressive. I will try to pit some hours on the HD650's this weekend and give a more informed impression. My ears can only handle so much Grado duty before they need a rest. Not from the sound, but from the comfort factor.
thanks, jdkJake..
it'd be great if you could compare it to other branded high end amplifiers like gilmore, schiit, wooaudio, or any other amps
- Headphone Systems
- "The Wire" Ultra-High Performance Headphone Amplifier - PCB's
