now the board uses DN2540 in TO92 package ... it takes nothing to modify it or maybe add this FET too in the GB
hi Gluca,
i am all for it, i would like to-92 DN2540's, 30pcs please...
why is there so much interest in this fet, I have never seen it mentioned in any diy threads?
You probably don't read the Tubes forum.
OK makes sense then Having said that I have two tube preamps, one of which I made (bitches brew) and I want to build another,either aikido or rtp3.
IXTP01N100D
Revintage (Sweden): 50
Bayermar (Germany) 20
Tony (Philippines):30
Gluca (USA):10
Bas (Netherlands): 32
qusp (Australia): 20
leadbelly (Canada): 10
vince (Italy): 10
vgeorge (greece): 10
danFrank (USA): 30
mach1 (Australia): 32
TO92 DN2540
Tony (Philippines): 30
Gluca (USA): 10
What about the PCBs? Any interest in them?
Gluca (USA):10
vince (Italy): 10
danFrank (USA): 30
TO92 DN2540
Gluca (USA): 10
Hi Gianluca,What about the PCBs? Any interest in them?
You mean the complete PCB as shown? Or a little PCB for a cascaded CCS?
I would be interested in a little PCB for a cascaded CCS.
Bas
IXTP01N100D
Gluca (USA):10
vince (Italy): 10
danFrank (USA): 30
au-trovaille (France): 30
TO92 DN2540
Gluca (USA): 10
Bas (The Netherlands): 32
Bas I was referring to the complete pre but not a problem to crop it to a small PCB. I'd prefer to maintain the heatsink on the PCB because FETs need to be isolated and this way thing are much easier and safer. What about the B+ regulator? Included on PCB or not? You need a super clean B+ when using the CCS as mu-follower.
Gianluca
Gluca (USA):10
vince (Italy): 10
danFrank (USA): 30
TO92 DN2540
Gluca (USA): 10
Gianluca
IXTP01N100D
Gluca (USA):10
vince (Italy): 10
danFrank (USA): 30
tonywong (Singapore): 20
ccliu (Taiwan): 20
TO92 DN2540
Gluca (USA): 10
Gluca (USA):10
vince (Italy): 10
danFrank (USA): 30
ccliu (Taiwan): 20
TO92 DN2540
Gluca (USA): 10
IXTP01N100D
Gluca (USA):10
vince (Italy): 10
danFrank (USA): 30
TO92 DN2540
Gluca (USA): 10
Gluca (USA):10
vince (Italy): 10
danFrank (USA): 30
TO92 DN2540
Gluca (USA): 10
IXTP01N100D
Gluca (USA):10
vince (Italy): 10
danFrank (USA): 30
panons29 (greece): 40
TO92 DN2540
Gluca (USA): 10
Gluca (USA):10
vince (Italy): 10
danFrank (USA): 30
TO92 DN2540
Gluca (USA): 10
Mine is omitted. Add back.
IXTP01N100D
Gluca (USA):10
vince (Italy): 10
danFrank (USA): 30
ccliu (Taiwan): 20
TO92 DN2540
Gluca (USA): 10
IXTP01N100D
Gluca (USA):10
vince (Italy): 10
danFrank (USA): 30
ccliu (Taiwan): 20
TO92 DN2540
Gluca (USA): 10
Ciao Bas
if you look at my schem at post #18 you will see the regulator on the left: it is a CCS shunting a big resistor and feeding the gate of a high voltage MOSFET: the CCS runs at 5mA and sets the voltage at the gate of the MOSFET, the regulated voltage at the source of the MOSFET is 4/5V below the gate voltage. Nothing fancy but it helps in knocking out +50dB of noise. On the right the CCS and tube (that we can eliminate from the PCB). When you use the mu-follower output form the CCS the power supply noise rejection is poor and you want it to be as clean as possible in preamps. So I thought that retaining the regulator on the PCB might be useful. In case you need the CCS for a long-tailed pair or cathode followers (ie on cathodes) the regulator should be bypassed.
let me post a semplified schematic.
IXTP01N100D
Gluca (USA):10
vince (Italy): 10
danFrank (USA): 30
ccliu (Taiwan): 20
TO92 DN2540
Gluca (USA): 10
DanFrank (USA): 30
I will take 30 of the TO-92 DN2540 also (as per above)... Thanks, Daniel
Gluca (USA):10
vince (Italy): 10
danFrank (USA): 30
ccliu (Taiwan): 20
TO92 DN2540
Gluca (USA): 10
DanFrank (USA): 30
IXTP01N100D
reVintage (Sweden): 50
Gluca (USA):10
vince (Italy): 10
danFrank (USA): 30
ccliu (Taiwan): 20
TO92 DN2540
Gluca (USA): 10
DanFrank (USA): 30
reVintage (Sweden) 10
DN2540 as added to the list above.
- Group Buys
- IXYS IXTP01N100D for non-USA citizens Groupbuy
