Oh, I see - they are polycarbonate. Never had them before.....
Anyway:
I tried the no cap option, with about 50-150mV DC on the outputs. It tended to vary about a lot, but didn't go above those values (when warmed up, it started off at 1.5V).
No doubt this is very clean sound, very good tonal range and even throughout. However, I went back and put the MGBO-1 back in and its very hard to hear any difference. Seems to me that this one is the one to keep in there. Seeing as I can't really hear much difference from a piece of wire, it gets my vote. Also, not sure that theres much point in bypassing it either......
The only bit of experimenting I would like to do is to try the 10uF versions of the same cap in there (the one I've used so far is 4uF).
Fran
Anyway:
Fran
I'm often using those russkie papers
small MKC as bypass is always good - to speed up things a little
try from 10nF upwards
and no - I don't have extensive stash of those
Jaccollina have stash of everything , as already known
Did a search but didn't find any mkc in my parts box. I do have some wima fkp 10nf and I added those in. It's hard to detect any difference. I think it might be a little smoother, the little bit of edge is gone, but that might have gone anyway.
Certainly hasn't done harm anyway.
Fran
Fran
So I think I've settled on some choices:
C10 coupling cap, 10uF MGBO-1 russian cap with a 10nf wima FKP as bypass
C7 and C9 4uF MGBO-1 also bypassed with wima FKP 10nf
Sound now is very smooth and 3D. Definitely an improvement on the panasonic FM and Cornell CDT caps previously installed. Only thing is that these caps are so big I need to be ab it clever with how to hold them in place. Thanks to all who suggested and helped out here.
Fran
Fran
Obbligato Premium?
In the German AAA-forum also was a discussion about the output caps. Some people prefer the Obbligato Premium 4.7uF. Would this be the perfect choice ore is the Russian MBGO-1 with bypass cap the winner? Anyone any experience?
Fran
Drop me a PM with your particulars, and I'll send you a few MKC caps.
Magura 🙂
stash of everything
Not much glory in MKC (but i think i manage 1F easily.
Thanks to all for yuor encouragement and help!
zygibajt: I will search for those caps, although I can't ever remember coming across them anywhere yet.
Try eBay they show up very often. Siemens MKV is just extremely outstanding cap as signal capacitor. Bosch MP is also extremely good although a tiny bit outperformed by Siemens. This is not only my opinion , you can google it.
You will not find anything even close to those below the level of Mudorf Silver in Oil or copper/oil jensens and the caps that would outperform Siemens and Bosch a little are V-Caps and Audio note but this cost a small fortune.
The Russians are quite fine, better than most of those audiophile crap out there below some usually very high prices. They actually showed me how huge diffrances the cap may do. But Siemens and Bosch is just another level.
If you want high quality audio without spending few hundreds bucks for a good signal caps. The only way to save the money if you have space inside component and do not mind use old used caps are the two above and maybe some others I stil haven't tested
Thanks guys - I'm going to watch out for those siemens caps - and the phillips mkc arrived today!
- ONO output cap choice
