hi there am running an EMU 0404 and trying to get soundtester to work with it but i am having problems, when using the ASIO driver i cannot select any sampling frequency other than 44.1kHz. Is there any particular setup for this combination? Alternatively is there another audio measuring software package that does work well with the EMU but doesnt cost a fortune? I am using Windows XP 32bit with service pack 3 and v1.3 drivers for the EMU (not the new beta drivers)
Try Arta
Hi Jakruby,
I am using Arta successfully with the external EMU 0404, see link.
http://www.diyaudio.com/forums/equipment-tools/180003-audio-signal-generator-fft-scope.html
Also did you set the sampling rate to 192 in the EMU USB audio control panel before starting soundtester?
Hi Jakruby,
well i switched to AARTA and it all works beautifully now!
Good to read that you have a working setup now.
