Semisouth Aleph J?
I was just reading the literature. They are acknowledging that a certain amount of gate current flows below the threshold voltage but not at the level of a BJT. I suppose a person would have to measure it to determine if it is a concern. I bet there is at least one person who has.
Papa sez - no gate leakage
Papa made paralleled Jfets in input LTP
I already wrote somewhere my reasoning for that - lower LTP drain resistance , due to lower Vgs of SS - means lower OLG
double input Jfets - double xconductance - even with wvwn lower Rdrain , means higher OLG
uh my brain is hurting ....... :rofl:
There is in fact Gate leakage, and devices should be tested
for excessive Gate current. Usually it's below about 20 uA
for this application, but I have seen a couple of parts that
were 10 times that. They work fine, but you have to make
an allowance for high Gate current when you have a high
impedance driving it.
clarify question
I thought i read somewhere that a higher bias sounds better. Problem is, it creates more heat. IRFP's can only take so much, so bias is limited unless using more devices. More devices, more noise. Device that can take more heat allows higher bias with fewer devices and less noise. This is a very uneducated answer, if not already apparent.
several times here is written that practical limit for mosfets is around 50W , if you use more powerful ones - IRFP150N per instance ;
there is no reason to torture other device in same package with more , even if that device is capable of taking more .
first important thing which is often neglected , in making any Papamp , is - one is making amp with original price above 2 or even 3K$ ( still bargain for that quality !) ....... and why skimping few $ , doing that ?
btw. "more devices - more noise " is wrong assumption
Matched Quad of SS R100 for sale
the matched quad is from a group buy of tea-bag.
I do not have the time for building an amp with
Not used and stored in static foam
Diy'er with interest , please send me a pm.
Regards Sam
