Genalex KT88 Plate Dissipation Question
I just received a new set of Genalex Gold Lion KT88s.
I am looking for the recommended plate dissipation for these tubes. Current B+ is about 505 to 510 VDC.
The cathode has a 10.16Ω*resistor and I measure the voltage across that resistor. That voltage is now set to 0.567 VDC.
I calculate the plate current as follows:
P (watts) = (505 VDC * .567 VDC) / 10.16Ω = 28 Watts
So I think that seems like a good target, but wanted to hear form others using this tube where they recommend to set them.
The amp is a home brew Williamson design using Edcore output transformers in ultralinear configuration.
Bias is fixed bias. I'll see if I can post a schematic.
I was using Ruby tubes, but one of them malfunctioned and its current dropped to zero. So, I had an excuse to order some Gold Lions and they arrived this afternoon and they are now burning in with the plate dissipation set to 28 Watts. ;-)
Your operating plate voltage would be a little down from 505V due to OT primary resistive drop. Your operating anode current would be a little down on cathode current due to idle screen current. They may reduce your actual plate dissipation by about 5-10% from what you initially calculated.
Thanks! Yeah, that makes sense. I just wanted to get a feel if others are in agreement with my target dissipation.
I should measure the actual voltage on the plates when I get a chance, but I think it is very close to the 505 VDC figure.
Genalex rates these at 35 Watts maximum. I don't know what the new version of these tubes really are rated for, but 28 should be a safe bet, I would think.
