NPC - SM5861 Dac
Gee Vasil that would be great.
The player is an Integra DX706 which I think is almost identical to the 708 so either one would do.
In any case I'm also looking for the DAC spec sheet SM5861 in order to change the output configuration since I may be using only one Dac for the output to the analog stage which will be redon compleatly.
Thanks for your help :cool:
Taking this thread out from the grave,
anyone with the datasheet of this AS version?
Hi
I am in the process of upgrade my 6850 to 6870 adding a vanguard 0.3ppm, oscillator and populate the empty space on PSU unit. I would like to change the 5V regulators with low noise regulator from Dexa.
If any one have more to say about upgrading this player I would like to know.
Best regards
Gabriel
