Is there any particular reason you can't/don't want to use a higher B+?
Compact PCB mounted transformers are commonly available and ideal for this sort of application; take a look at the hammond 229A230, it's available for around $15.
At 30v, you're going to be operating in a very non-linear region unless you increase the current to something crazy high.
You'll also be driving the grid positive at times which should generally be avoided...
For the cost of the transformer plus a few parts, you'll really free up your options for the preamp design.
mainly so i could run the SS parts from the same power supply, just dropped down to 12v, but that looks good i might have to consider that,
For an instrument amp, this need not be a problem at all. Just try it out to see if it sounds good. It might even be a good way to get a nice 'crunch' without using too much gain; tubescreamer style sort of.At 30v, you're going to be operating in a very non-linear region <snip>
Yes, I've been considering something similar for a tube amp build---really like the fat tone of Fender's Supersonic but would like to find a simpler, lower cost way of doing the same thing. Fewer tubes with fewer and lower B+ rails with a solid state power stage seems like one possible way of achieving that. Though from the handful of 12AX7 datasheets I've looked at so far I was thinking more like 150 or 200V.
the lowest ive ever ran a 12ax7 successfully at with not bat results was at about 80v, thats why im considering a 12au7, ive used them a few times in a 12v application. but only with one tube (in things like a booster pedal or driving a big EQ). im not sure about multiple tubes to get a high gain sound though, or what it might sound like...
yes, its an old solid state amp i have, i have a 30-0-30v transformer and dont really want the hastle of getting an output transformer for it, and finding space on the chasis for it. im pretty happy with an SS power amp seeing as i never really drive it that hard
It was suggested that one may want to use the low voltage space charge tubes for this type of application. They are cozy with 30VDC for plates. I haven't tried one myself yet but I do have several schematics of a low voltage 24vdc tube amp around here somewhere that use them in a push pull configuration. The 24vdc amp was even shown on YouTube. the designer built both a 24vdc and a 12vdc guitar amp, which he also demoed.
yes ive used these tubes before, i do have a spare 12k5 laying around which im not sure if it would be an ideal pre amp pentode or not
What sort of load line was that on?the lowest ive ever ran a 12ax7 successfully at with not bat results was at about 80v
i cant remember exactly, it was alot of guess work, i ended up changing what i designed on the datasheet completely
Ah, ok, thanks anyway. Given the amount of tone tweakery possible I'm starting to wonder if I should just build the amp with a bunch of pots so I can try different load lines and B+ regulator output levels. 😛
well i have been designing a preamp with as many tone options as possible, if your interested, basically, cathode caps on a rotary switch to switch between them, along with dpdt switches to change coupling caps. as well as a 100k pot with a 470pf cap to ground on the first attenuator stage (from the wiper of the gain pot to ground) basically i was looking for as much preamp tone control, without having a typical tone stack. im not sure about pots for power rails as you may need some pretty high power pots, though putting some resistors on something like a 3 way dpdt (on/off/on) on different filter stages might be a better idea.
An LM317 with a variable reference created via pot will suffer breakdown well before the thermals of supplying a signal tube are a problem. If you get into cascodes like what tomchr's doing some attention to the pass device may be needed when dropping B+ by a couple hundred volts. That's fairly extreme tunability, though.
Hadn't thought about using switches over caps (or jumpers if B+ is low enough for that to be safe). Thanks for the suggestion.
- Tubes / Valves
- low voltage "high gain" amp
