Comparing power supply of F-5 to F-1
Joined 2003
Looking at the F-1 power supply schematic and noticed it was extremely similar to F-5 with one exception:
The F-5 has a run off of the power supply ground, leading to the CL-60, which then goes to chassis ground.
The F-1 appears identical, except each cap bank has its own CL-60 going to ground, and they are not linked as in the F-5.
Can someone explain why this is, or would either amp work either way? I'm sure there is a simple reason I just am not aware of?
Russellc
osmozis will tell ya that
in F5 your nose is between two eyes
in F1 there is no nose ...... and eyes are wandering around ......
Oh I get it 1 Bipolar psu as opposed to 2 polar, on the lower channel if i use F1 psu board flip the polarity of the input from transformer flip my filter caps loose one thermistor tie lower + to upper -??? So i have B+ O B-
Dazed and confused , Elwood😕
