just curious if anyone has compared the sound between simple DC heater psu vs. Volt. Reg. PSU.
1. F.W.B to R to C (10,000uF)
2. F.W.B to LM1084 V.Reg.
I'm wondering if the the volt. reg. heater psu limits the sound. This is for line stage.
Hi!
If this is for indirectly heated tubes, the differences will not be worth worrying about.
If this is for directly heated tubes, neither will sound good. Either use a current reg, or the dedicated fil regs offered by Rod Coleman, or use the purely passive LCL approach which I prefer
Thomas
Thomas
I disagree, Thomas.
In my recent 4P1L project I used floating 6.3V voltage stabilizer (for indirectly heated), and 3 Ohm resistors in series with each half of 4P1L filaments. No difference in sound VS floating batteries.
Hi!
I wrote that there will be no significant differences with indirectly heated tubes so I guess we agree 😉
Thomas
Thomas
Hi again,
just saw in your other thread, that the tube you mentioned is actually directly heated.
Ok, if you don't hear a difference with that one, it doesn't mean that there will be no difference with other DHTs. I got significant differences between filament supplies with DHTs. Some respond more to the fil PSU, some less.
Generally my first axiom in audio is:
If you can't hear a difference, it does not mean that there really is no audible difference. Of course the opposite holds true es well: If you hear a difference, it doesn't mean that there really is a one.
Best regards
Thomas
Best regards
Thomas
Agree! 😀
Thanks Thomas.
yes, for indirect heater. 12au7, 6DJ8,etc...
I have never played with DHT's.
I do prefer using the LM1084 for fixed voltage, soft start and some short circuit protection for sanity.
If you can't hear the difference,............, you save a LOT of money!!!!! 😀
I had trouble with hum in my pre amp so I changed to DC heaters and the hum was still there. The hum was coming from other sources like transformer magnetic field and bad wiring.
I've tried several DC heaters options for DHTs. I'd rank them as follows:
Best:
Choke input supply followed by Rod Coleman board
Double choke input supply
Then:
Rod Coleman board
Then:
LM1084 as current sink
LM1084 as voltage reg followed by a CMC
(The above are improved by a further LM1084 before, as Ronan Reg)
Various other common voltage regs
I didn't find batteries were necessary or much better and wouldn't go to the trouble of using them.
Andy
Best:
Then:
Rod Coleman board
Then:
Andy
Hi!
Different types of filaments also respond differently IME. The 801A / 10Y family the most. Also the further upstream in the signal chain the more critical it get's.
In a linestage a 801A can sound anywhere from unbearable to absolutely wonderful depending on the filament supply. But worth the effort IMHO
Thomas
Thomas
- Tubes / Valves
- DC Tube Heaters
