From same interview... "By the 2020s we will be placing millions or billions of nanobotsblood cell-size devices inside our bloodstream to travel into our brains and interact with our neurons. "
Mr. Kurzweil is prone to hubris.
Honestly, I'm not so sure about that.😱
Computer Chips Wired With Nerve Cells - Science News
As an aside. Scott, has the problem in Japan affected the supply chain for the thermoset plastics or glob top normally used in IC production? I shudder to think your guys stick to JIT.
We've a lot of IC's on order for our widgits, so I worry..🙁
On another general note, anybody read the NASA report on unintended acceleration and tin whiskers?
Cheers, John
Well, that eliminates one obvious potential explanation 🙂
JM
Power went off last night due to a storm, so I shut down the experiment. Turning it back on today showed less loss as expected from the inrush current but still more than at the start. So a good idea of what else to check and it may be a small contribution, but the results really do seem to support the slow B/H loop shift.
So why are you on this thread offering reasonable questions politely asked? Haven't you read all the other posts?
John, I think is taking a break because he really takes his longer "teaching" posts seriously. It seems to take him a bit of time with his old guy vision to actually post a few hundred words. So when he hits "Submit Reply" and it fails to appear he gets quite discouraged. (Polite word for really f.. ticked off.)
ES
JM
ES
John needs to use the "textedit" app to create his texts then use the apple key + a, then apple key + c and then apple key + v. theat will give him all his text in one go into the message box.
Wrinkle
PS my money is on the transformer saturating.
The discussion about transformers seems to be over but here are some measurements :
Lundahl 1545a Audio Transformer
Ahhh, transformer for line levels. That's what I did a lot some 20+ years ago. I have very good experience with the Lundahl transformers, my favorite Xformers where the LL1524 for line outputs and the LL7101 for line inputs.
If you're concerned about THD, use the 7101 in "balanced zero field" mode, i.e. as a current transformer at virtual ground. And for output transformers, feed 'em with negative output impedance equal to their DC resistance. And if you want to go crazy, add some circuitry to compensate for resistance variation with temperature.
But hey! This is real balanced. Not the ground referenced crap that "high end" audio often uses.... 😀
Why not? All that acrimony seems like it would be exhausting.
Anywayz, it occurs to me that the DC in your input could generate significant DC current in the transformer primary. Could you possibly be saturating the transformer core?
Ahhh, you young guys...you crack me up..😀
I believe you are correct...
I think Ed mistook my reference to SCR's as "silicon controlled rectifier"...
I believe I gotcha Ed..
Saturable Core Reactor...the first dimmers...
Cheers, John
Cheers, John
John,
I saw my first "reactor" in 1970! But the Silicon Controlled Rectifier when used in industrial controls is one of the causes of DC on AC power lines.
Yes I am of the firm OPINION that what is happening with the transformer's loss of output is the low level DC current is slowly moving the center of the BH loop so at one extreme it gets into a more nonlinear edge and reduces the output voltage and increases the distortion.
Since I know the problem actually can happen and how to measure, correct and avoid it, I can move on to other items.
ES
Cheers, John
There is some concern about starting material, but I don't recall the Sendai area being a big producer. I've been there and felt a small quake getting off the plane, gives one pause. The food specialty is horse sashimi BTW.
Jneutron, read the NASA report, they are also doing more testing on lead free assemblies, white papers on IPC site. Finding Tin whiskers on the Toyotas is going to put back any chance of mil/areo/space moving to lead free solders for even longer, this wouldn't be a problem if you could get components with tin/lead finish. The main problem is with BGA devices, these have to be re-balled putting them through a heat cycle before being assembled! When you look at the amount of lead in PCB assemblies (less than 1% before the lentil eaters got their way) and how much effect it had on lead polution, you have to ask yourself whether it is worth the increase in burning fuel (CO2 emmisions) to support the higher reflow termperatures.
We've been studying the feasability of going lead free for several years now, it also is going to effect this 'IPC Printed Board Defense Roadmap – Future Needs of Printed Boards in Department of Defense Electronics Identified by the North American Electronic Interconnect'. It hasn't improved our confidence in lead free reliability, for use in adverse conditions or high rel products.
