I went through a few profiles and did not see anything larger tha 1" base and fins.
10.080" - HeatsinkUSA, LLC Store
note that what is called length may be what you understand as height
reason for calling it length is that they start with a raw length they cut up
so technically for machining its length
but when you build your box it becomes height
was that confusing enough 😛
